Question about Samsung RB215LASH
Fridge not cooling
My refrigerator has not been cooling, I took the panel off from the inside of it and the coils in the fridge were full of ice. I defosted it with a hairdryer and has seemed to work for a couple of weeks. But it seems like its starting to do it again. Is it low on freon or is there something else I need to clean thats causing this problem. The fridge is on about 3 years old and its a samsung
    Scholar:
  • 149 Answers
Check the following is freezer fan running? if so that's o.k.
if you handy with a voltmeter put it on the "beeping feature" disconnect power from fridge then disconnect the two wires from the defrost heater put one lead from the meter on one side then put the other lead on the other side if it beeps its good if it doesn't bad defrost element replace it and replace the defrost thermostat
Posted on May 09, 2008
Freezer not cold enough fridge fine
The issue is the defrost timer.
Jul 10, 2013 | Amana Refrigerators
Whirlpool fridge/freezer ARC 7050
see if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Dec 06, 2007 | Refrigerators
My whirlpool fridge is hot, took the cover off of the coils inside freezer, look ok. Took back cover off of the back and the compressor is hot
Hi jason;
Shall take it that you have a Side by Side setup? If so with rear cover off, when you start it does the cooling fan come on beside compressor? Also remove front grille and clean front condensor coils, full dust and hair all problems can happen. (like blocking of car radiator). Try these if fan doesn't work, replace.
Mar 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge side is not cooling below 50
if the front panel was full of lint then the coils inside are likely really clogged ... usually the front panel at the bottem of the fridge comes off .. you need a flat attachment on your vacuum to get between the coils .. you can also use a long bottle brush but it gets messy .. you might be able to get at the coils from the back .. there is a cardbord screwed on that once you remove, you can get at the fan and coils ... make sure its turned off/unplugged before doing this .. once you have cleaned the coils then you might wait a few hours or overnight with power off and doors open if you can .. the evaporator inside might be iced up ...that should thaw it ... put towells down to soak up any water that comes from the melting ice .. i usually put everything in insulated picnic baskets while the thing thaws out ... maybe a neighbor would lend you some freezer space ...
Aug 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Oct 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerator isn't working anymore
Try to completely defrost it, then if the freezer works but not the fridge change the thermostat
May 31, 2008 | Kenmore Refrigerators
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Samsung RB215LASH Logo
286 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
