Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
I have a waterway mustang 56 pump. Pump just hums but does not start up.
    Problem Solver:
  • 10 Answers
Check the capasitor under the small cover on top of the motor look for bad wire or swelling anywhere on the capasitor the motor will not start if it is bad
Posted on Sep 01, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Motor hums but does not turn freely, can you turn the motor by removing the motor end cap?
no! You have to remove the pump end to find the shift, You may look between the pump and motor and find the shift splice and set screws that need to be tighted up.
Sep 16, 2013 | Waterway Spa Pump Executive 56 Frame 4hp...
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Pump acts like it is froze up. It hums and smells like it is burning when it runs. It hums then shuts off, hums then shuts off?
Either you need a new start/run capacitor or the bearings have seized. If it's been running loudly recently, the bearings have probably seized. If not, the start capacitor is probably bad. This can sometimes happen when the motor windings start to develop a short. If you replace the capacitor and it blows again, you'll probably need a new motor.
Oct 22, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Is any one else out ther with a Waterways 56 pump replacing them every 3 years also?
The UK versions of the Waterway pumps seem to be very reliable. The only known issue is with the Run/Start capacitors which tend to fail but they're easily replaced.
Over the years I've heard of many pumps being changed unnecessarily.
Regards,
Ian.
http://hottub.synthasite.com
Jan 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Our hot tub uses a Waterway Pump. We emptied the water and refilled it with clean water. The pump now just hums... and doesn't pump. Did we do something wrong? Is there a solution. It is 220V. The...
Was the pump working prior to the cleaning or had it been sitting dormant? The motor relies on a starting circuit within it to operate. One of the components can be bad or the pump can be siezed up.
Turn off the power and remove the back cover from the motor. Try to turn the shaft by hand. Is it free to turn? If so, the problem is inside the motor. If not, look for the obstrction.
A local electric motor repair shop can help you if you find damage in the motor and/or pump.
Dec 27, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
My Mustang pool motor by Waterway musts-120 is just humming when it is turned on. It is connected to a timer, but the pump is working fine, just the motor is humming. What do I do? Is my motor toast?
Check your loacl yellow pages for an electric motor repair shop. They may find it is fixable but could at least tell you if it is salvagable or not. Some even carry replacement motors at costs lower than the pool stores.
Jun 10, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
194 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
