Question about Vivitar ViviCam 8025 Digital Camera
Card protected what does this mean - Vivitar ViviCam 8025 Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
Get it off "protected card" mode?
If the card is a Secure Digital (SD), SDHC or SDXC there is a write protect switch on the card which can be slid up and down. Up means it can be written too, down means the card cannot be written too. If the card is in the position where you can write to it but the camera is saying the card is still protected it maybe a faulty card or the camera may have a fault.
Sep 19, 2014 | Fujifilm Finepix F300exr Digital Camera...
What does write protected mean?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 03, 2014 | Nikon Coolpix S6100 Digital Camera
Write project? what does this mean on your camera
I assume you actually mean "write protect".
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 24, 2012 | Cameras
My camera had a white-protection
Do you mean "write" protection instead of "white protection"? If so, look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 26, 2012 | Kodak EasyShare M530 Digital Camera
What does write protect mean
It means that your memory card has been protected from writes, preserving its contents.
Feb 11, 2012 | GE X500 Digital Camera
What is the meaning of card is protected?
Than means you can't erase the data on that card without a password, or administative controls. Someone somehow had requested to make this card protected.
Dec 14, 2010 | Fuji FinePix S1000FD Digital Camera
What does it mean when my nikon coolpix s60 displays Memory card is write protected?
It means the card has been protected from writing, preserving its current contents.
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 08, 2010 | Cameras
When I try to take a picture, it says "card protected!?" What does that mean, and what do I do about it?
It means the memory card is write-protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 12, 2010 | Cameras
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
Vivitar ViviCam 8025 Digital Camera Logo
88 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
