Maytag MAH8700A Front Load Washer Logo
Anonymous Posted on Aug 31, 2010
The clothes smell after washed...the drain is not plugged by a coin or other obstruction...however the drain hose has a slime film starting from the pump to the wall drain...the check valve after the pump is still intact and functioning...
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 31, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10843921
Points
101584
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
I found coins in pump and removed but still not draining correctly
If all obstructions are removed, and still doesn't drain, replace pump.
Bush manuals
hi there.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
or read up more at this link might help you some more.
washing machine wont spin or drain Google Search
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES...
hi Luis.
Drain Pump
Drive Belt
Lid Switch Assembly
Drain Hose
Coin Trap
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
2helpful
I have a BEKO wm5100w and it has started making an awful noise when draining. Its definately not the spinning, ust the draining. It also leaves the clothes with a funny smell. What could be the problem?
hello sound like there could be somethink stuck the in the pump like a coin or metal also check the filter if it has 1 and check the drain hose. hope it helps
regards
shaun
1helpful
Machine is making a loud clicking sound and will not spin out clothes
you need to check the main drain pump and all the hoses leading to the pump for any thing that will obstruction the flow or operation of the pump.Be sure to remove the drain hose that comes down from the tub to the drain pump and remove the plastic coin trap and clean it out.depending on how much close you do the coin trap should be clean about once every 6 months or sooner if you do alot of clothes.
2helpful
Water not draining after the wash cycle
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.
1helpful
Moldy smell
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The problem is design. Not all of the water is getting out after each cycle and not all of the soap gets fully dissolved. After awhile, this mucky slime gets 1n the drain hoses, pump and filter - and they all smell musty - especially when the machine sits empty with the door closed between loads.
You need to clean the innards of the machine by doing a load without clothes on hottest setting (Whites) and depending whether the smell is bacterial (add 1 cup White Vinegar), fungal (add 1 Cup Bleach) or clogged filter (add 1cup Arm and Hammer with 1/4 cup SALT), this should do it
(Vinegar for Bacteria, Bleach for Fungus and Arm and Hammer with SALT to soften and loosen the slime)
Choose from above (not all 3 at once tho) and fill the machine with water and let run without clothes.
I would do the A&H with salt first, let cycle complete, then restart and add a cup of Vinegar, tel cycle finish then redo with 1 cup bleach
After treatment, leave the front door open after doing laundry from now on so it can thoroughly dry out and get air circulation. - Just open, not WIDE open ;-)
Cheers!
4helpful
Have a philco ecotronic washing machine and the clothes smell a little after they have been washed. Do you know how to get rid of the smell on the clothes, is there a filter that needs changing? thank you
2answers
Dirty water
are you using liquid detergent? if so, don't. liquid detergent has the side effect of leaving a nasy smelling slime inside the machine and think this is what you are seeing on the drain hose. if i'm right, put appliance oin boil wash when empty and use powder detergent
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
