Question about NetGear N150 / RANGEMAX 150 Router
All correct lights appear on the router but will not connect to internet
  • 550 Answers
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Sep 01, 2010
3 Suggested Answers
  • 226 Answers
SOURCE: wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Posted on Jan 23, 2010
SOURCE: have cable--can't get internet when
you have to set the wireless settings or the settings of your router before you have the connection ..
Posted on Nov 01, 2010
I got n300 router and cant connect to internete
hi there!
well there are so many things that you need to check for "i cant connect to internet" issues. first is cant browse any websites at all, if the pc showed signes of being infected with viruses, if the router is powered on, etc. you may wanna check if the router is connected with the correct cable to the pc and to the correct port aswell. check on the router lights too, the router manual will give you the meaning of the colored lights on the router! =)
Apr 06, 2011 | NetGear WNR2000 Wireless Router
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I cannot connect to the internet. I am using a netgear rooter. Although I am connected to the router I cant get through to the internet
moz-screenshot.png1) Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click correct Local Area Connection by identifying correct network card and click Properties.
4) Select Internet Protocol (TCP/IP). Click on Properties.
5) Then try assigning the following values (default) and Select OK.
Nov 18, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
Xomputer will inexplicably lose the signal. A few
I think the problem must be with the router. When it drops the connection, you can see other networks but not yours.
that means at that time the wireless signal on your router must not be broadcasted.
WRT160N router has issues with the firmware. Youcan try to upgrade the firmware of the router.
firmware is the software of the router.
Once you upgrade the software, unplug the power to the router and plug it back in. wait for a moment and now observe the connection.
Click here for more information about the router and internet
Feb 26, 2010 | Linksys WRT160N Wireless Router
Can connect to internet with linksys WRT310N
If you are on Cable Internet, you need to do MAC Cloning. Open the router's Setup Page through http://192.168.1.1 then look for Mac Address Clone sub-tab under the the SETUP tab. Enable it and click on Clone My PC's MAC then click on Save Settings. You need to power cycle the device now. Unplug the power to the router and the modem. Wait for 30 seconds. Power on the modem first and wait for the lights to go solid, then power on the router. You should be good to go.
Jun 23, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Neatgear WGT624 take over
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 06, 2008 | NetGear WGT624 Wireless Router
Netgear614 to compac pc laptop
hello!
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Ive installed xp on my acer travelmate 4100 laptop
hello!
Apr 22, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
NetGear N150 / RANGEMAX 150 Router Logo
95 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
