Question about Aastra Telecom Aastra 57i CT
My Aastra IP phone is giving error message when I plug the Power and LAN cable. "Application not found, to restore, go to recovery web page at 169.254.75.126" While my ip address should be 19.168.1.XXX. I tried holding the # key with number one to get new IP address but it gives me the same IP address. Any solution.
How do I hard set a Aastra 6730i
A hard reset is simply remove power and re-connect. If this fails, check the network connections by logging onto the web interface, you can find the IP address from the settings menu.
Sep 05, 2014 | Aastra Telecom Computers & Internet
Not connecting to LAN Network
The basic LAN setup for my xxLE820N was to connect an ethernet Cat5 cable between the TV and my home router. Power on the TV and check your router admin page to see if the TV is being provided a local IP address. (Note: router must be configured for DHCP service.) On the TV remote, press the 'aquos net' key 2-3 times to switch the TV to web mode. If you get an error message, your router is probably not configured appropriately.
May 04, 2014 | Sharp Aquos Televison & Video
Turn on shuts off blue screen B8000028
The steps to resolve this issue on a product that you want to set up with a wireless connection and on a product that you want to set up with a wired, or Ethernet, connection differ slightly. Depending on the connection type you want to set up, select one of the following methods, and then follow the steps provided to resolve the issue.Method one: Resolve the error on a product that uses a wireless connectionStep one: Print a network configuration page
  1. Disconnect the power cord from the back of the product.
  2. Remove the phone or Internet cable that is connected to the back of the wireless router. Do not reconnect this cable until instructed to do so.
  3. Reconnect the power cord to the back of the product. If the product does not turn on automatically, press the On button (c00636182.gif ) to turn the product on.
  4. Make sure that the blue Wireless light is on. If the Wireless light is not on, press theWireless button on the front panel of the product to turn wireless on.
  5. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  6. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  7. Press the Setup button (c01726396.gif ) on the product control panel, select Network , and then select Wireless Setup Wizard . Follow the instructions in the wizard to complete the configuration.
  8. When the Wireless Setup Wizard is complete, press and hold the Cancel button for several seconds. The network configuration page prints.
  1. Make sure that the computer is connected to the same router that the product is connected to.
  2. On the network configuration page that you printed in 'Step one: Print a network configuration page,' look in the General Information section. Make a note of the following information.
    • IP Address
    • Subnet Mask
    • Default Gateway
    note.pngNOTE:Each of these addresses is in the IP address format. For example, 192.168.1.100 is an IP address. Make sure that you note the numbers and the dots exactly as they appear on the network configuration page.
  3. Open a Web browser, such as Internet Explorer or Mozilla Firefox, on your computer.
  4. Type the product IP address in the address bar of the Web browser, and then pressEnter . The Embedded Web Server (EWS) page for the product opens.
  5. On the EWS page, click the Networking tab.
  6. In the left pane of the Networking screen, select Wireless (802.11) , and then select theIPv4 Configuration tab in the right pane.
  7. Select Manual IP .
  8. In the IP Address text box, type an IP address that is within the range of 192.168.1.10 to 192.168.1.60. For example, the IP address 192.168.1.25 is correct, but 192.168.1.61 is incorrect.
  9. In the Subnet Mask text box, type the Subnet Mask address that you located on the network configuration page.
  10. In the Default Gateway text box, type the Default Gateway address that you located on the network configuration page.
  11. Click Apply to save these settings.note.pngNOTE:After the new IP address is set in the EWS, the computer loses the connection with the product, and the EWS page becomes unresponsive. This is expected behavior. Wait 10 seconds, and then continue with the next step.
  12. Close the Web browser.
Step three: Restart communication and complete the installation
  1. Press the press and hold the Cancel button for several seconds. The network configuration page prints.
  2. Make sure that the product is connected to the network and that the IP address matches the IP address that you typed in 'Step two: Set the product IP information in the Embedded Web Server (EWS).'
  3. Connect the phone or Internet cable to the back of the router.
  4. Continue the product installation. If the software has already been installed, insert the software CD into the computer CD drive, and then select Add A Device from the menu that appears on the computer.
If the installation is successful and the error message does not appear again, the issue is resolved, and there is no need to continue troubleshooting.If the installation is not successful and the error message appears on the product control panel, continue with the steps in the Workaround section.Method two: Resolve the error on a product that uses a wired (Ethernet) connectionStep one: Print a network configuration page
  4. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  5. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  6. Make sure that the network cable, or LAN cable, is connected to the computer and to the product.
  7. When the product is connected to the network, press and hold the Cancel button for several seconds. The network configuration page prints.
    • IP Address
    • Subnet Mask
    • Default Gateway
  6. In the left pane of the Networking screen, select Wired (802.3) , and then select the IPv4 Configuration tab in the right pane.
  1. Press and hold the Cancel button for several seconds. The network configuration page prints.
Or else remove CMOS battery located on formatter, wait 15mts refix then check..
Oct 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I've got a Linksys WRT160N V2 router that stopped connecting to my modem last night. If I plug my computer directly into the modem, I can get Internet access, but if I plug the router into the computer and...
I had the same problem and found that the port was damaged and change to another port and work fine but after a few days working file it drops back again and no internet again. Tried all the other ports and no result. I found out that something is going wrong with a part in the router and when it heats up the problem repeat.
So my solution is Buy another router and my choice went to:
TP-Link TL-WR1043ND
Dec 16, 2010 | Linksys WRT160N Wireless Router
I am trying to connect netgear router to my modern ATT can you help me out?
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Jun 08, 2010 | NetGear WGT624 Wireless Router
Installing a netgear router
It seems that you need to reconfigure router ,you can use following steps to reconfigure router
16. Click Apply.
May 17, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear wireless-N 300 router directions
Direction for using and configure router
16. Click Apply.
Hope it can resolved your query
Thanks for using Fixya
May 05, 2010 | NetGear WNR2000 Wireless Router
Pc has been wiped now i want to reconnect to wireless router
Hi
please follow steps to reconnect to wireless router
16. Click Apply.
please rate service positively
Mar 26, 2010 | NetGear WGR614 Wireless Router
How do i hook up my netgear wireless with out the cd
Now please follow the steps to configure the router:
5.Login to the router (Username = admin Password = Password)
6. Click on lan ip setup under advance.
16. click Apply.
17. Open up another browser window and try to access internet.
regards
prakash
Mar 18, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Aastra Telecom Aastra 57i CT Logo
431 people viewed this question
Top Aastra Telecom Computers & Internet Experts
David Payne
David Payne
Are you an Aastra Telecom Computer and Internet Expert? Answer questions, earn points and help others
