Question about Vacuums
Replacing Switch & cord on OLD Eureka upright 403B or 403S (can't read)
I have ordered and received what seems to be the correct switch and replaced the belt, but cannot figure out how to get to the switch. I also need to shorten or replace the cord because it is severely worn where it bends onto the winding posts. This old vac worked well until recently and is the property of our church and we can't afford to replace it right now.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/support/t581907-replacing_switch_cord_old_eureka
Generic problem for all Vacuums
Replacing Switch & cord on OLD Eureka upright 403B...
Posted by volunteer2 on May 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a handle switch / cord and if you shorten the cord you need to also purchase a cord protector. Usually it may be covered by screws or a pop rivet and you would have to drill out the pop rivet and the switch cover will come off and then replace it with new pop rivets or screws and use the cord protector if you shorten the cord nut I would not advise it because the longer the cord the more vacuuming you can do without going from plug to plug. Suggest that you check with you local vac dealer in your area or use some suggestion I will give you listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S. Customer Service Canada
Electrolux Home Care Products Electrolux Home Care Products
P.O. Box 3900 5855 Terry Fox Way
Peoria. IL 61612 Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 | Vacuums
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Broken on/off switch
I have the same vacuum and the on/off switch wasn't working any longer so I took the cover off to find out that the wiring got so hot that it melted through the wire coating and plastic frame.
Aug 04, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 2961AVZ
http://geeksquad.fixya.com/ThreadView.aspx?prdid=538511&thid=720558
Eureka 2961AVZ
Posted by Joanschmuck on Jun 29, 2008
Will not start ...I get a momentary flicker of power about every 3rd or 4th time that I flick on the power switch. Outlet is fine / Plug looks good / cord looks good / I see no obstructions ........Would appreciate any helpful thoughts ....Trying to get Mom's Eureka 2961AVZ back up and running. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a bad switch or the worst scenario would be a bad motor and or armature, and the armature is almost the cost of the new motor, so I would replace the motor, but check the switch and the cord because sometimes the cord looks good but there might be broken wires inside the cord that you can’t see. If the vacuum is less than one year old the motor would be covered under the factory warranty if one year and maybe the switch as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service Dept 1-800-282-2886
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 29, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Jun 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 5892BVZ ON/OFF switch burnt
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893 bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Feb 01, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
107 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
