Question about Consew 207 Mechanical Sewing Machine
Consew 207 I have a sewing machine that will no longer pick up the bobbin thread. I have no manuals for adjusting the timing etc, is there anywhere I can get this information?
  • 323 Answers
SOURCE: Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Posted on May 14, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
kevin000
  • 1847 Answers
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
Posted on Sep 15, 2008
  • 980 Answers
SOURCE: I have a consew 206rb5 and it has been sewing
The machine is out of time, email me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on Nov 01, 2009
  • 6 Answers
SOURCE: I have a consew machine 226 and the needle thread
your needle is in backward, the groove must point to the left.
Posted on Jan 27, 2010
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
My husband purchased an old model Consew machine. It is mounted on a table and came with the instruction manual for models 225 & 226R-1. The machine will NOT pick up the bobbin thread. Any ideas?
Check your manual to see which way the flat side of the needle shank should face. With modern machines, it's usually to the rear, away from you, but with older machines there was more variation.
The most common reason the needle won't pick up the bobbin thread is because the flat side of the needle is facing the wrong way for that machine.
Hope this helps!
Robbie
Aug 07, 2010 | Consew 226R-1
Thread stuck around the bobbin housing on my
try cleaning all that you can out of the bobbin case then try very carefully to bump it backward (opposite) with the hand wheel . Be careful not to knot out of timing. sounds like you have thread in between bobbin case and hook
Apr 06, 2010 | Consew 339RB-3 Sewing Machine
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
sewman7
Aug 28, 2008 | Consew Sewing Machines
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Sewman7
Apr 27, 2008 | Consew 1118-3
Bobbin timing
yes its still outta time. go back and make shure the pick up off the needle is set just right. otherwise it will continue to drop stites and break thread. ull know when u have it right it wiill sew as it should
Aug 17, 2007 | Consew 206RB
Consew 207 Mechanical Sewing Machine Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
