Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Blinking Power Light 9 Times Phillips 60PP920299
I have an issue with my Phillips 60PP920299 where it turns on to static for a few seconds and then turns off and the power light blinks 9 times. Any ideas?
I am not having any lucking finding a service model anywhere and I have repaired other TV's before. Thanks for your help and time.
  • SolarCurve May 11, 2008
    I was able to fix this by simply replacing the fuses in the unit for $2.57 at home depot. w00t! :)
  • jerk85 May 28, 2008
    I have the same problem...what fuses did you replace? and do you have any pictures?
  • 121 Answers
Go to this link they may have your service manual for your tv they list them by chassis numbers so if you don't see it leave them an e-mail with your model number and they are very good about getting back with you
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
Blinking bravia sony
You can always try a power reset on the TV, or a factory reset if the TV is able to be powered on to working condition.
If the TV turns off a few seconds after being turned on and then the light blinks 14 times that likely means there is a power source issue of some kind within the TV.
Aug 11, 2014 | Sony KDL Televison & Video
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Televison & Video
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Power LED flashes and beeps (simultaneously) 9 times when turned on, 2 second pause, then 9 times again and again.
From everything I've been able to read,the problem is with the Bios chip on the motherboard.It's eithe AMI or AST Bios.It may be possible to fix it by resetting the CMOS settings,I'm including a link to detailed instructions with pictures.Don't be afraid to try.First UNPLUG the machine.On the back are a few screws that hold the case on,they come out with a Phillips screwdriver,then pull the case back and up.In the first picture you'll see the battery,bottom middle,about the size of a quarter.Remove that.Then scroll down the page and click on Clearing CMOS settings and follow those instructions.
One thing I should have said much earlier.Any time the case is open(UNPLUGGED)and you put your hands inside,make suree to maintain constant contact with a metallic surface with a hand,arm,something.You'll be dissipating static electricity.And please don't do this on carpet.
Hopefully that will at least get your machine running.
Then,we can hopefully move on to other issues as they come up.Let me know,I'll keep working with you.
Good or bad,please rate my post?
Thanks
Bob
Aug 11, 2010 | Compaq dc7100 Minitower PC Desktop
Tv turns on then gradually goes green in next few seconds and then comletely shuts off. The light blinks 8 times in a row afterwards then pauses. how can i fix it?
If the lamp light is blinking, then the lamp needs to be replace. If the Power/Standby light is blinking, then try resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the TV needs service.
Jul 26, 2010 | Sony KP-57HW40 57" Rear Projection...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
Hi: My KDS-50A2000 projection tv turns on for a few seconds to one minute and then turn off by itself. The power LED start blinking 9 times then stop and starts with the 9 times blinking again. I checked...
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Sony KDS-50A2000 50" HDTV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
196 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
