Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there is a disc in the player, the audio portion of disc can be heard even though the screen says "Unusable Signal". I've checked power cords and tried unplugging etc. but nothing gets me past the "Unusable signal" screen. Any suggestions??
  • 7 Answers
Check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Posted on Sep 01, 2010
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
I would like the multi zone code for a samsung V6800 dvd
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
Sep 28, 2008 | Televison & Video
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I have Samsung DVD Video Combo
player.
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
If the above codes don't work try 57538.
Hope this helps.
Dec 14, 2008 | Televison & Video
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO PICTURE ON SCREEN....SIGNAL MAYBE
Push the button pscan/normal that deactivates the function,or do this turn on the dvd get out the disc live the tray open and then push the stop button for 6 sec.Good luck.
Jul 10, 2008 | TruTech TT320
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
