Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Fridge serial number TFX22PPBAWWZV245881 freezer is frostibg up thenit warms up and doesnot keep the temperature at proper level Had same problem about approx 2yrs ago erplace part cost $208.18 Is this a faultly part??
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes they really don't make them to last much longer then the warranty...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
My refrigerator side is not maintaining a cool temperature, and the green temperature light is off (the freezer side works fine)
the problem is in the freezer side,all it does is blow clod air from the freezer to the fridge side so if the fridge is warm the freezer side is either iced up or the fan isn't blowing,open the freezer door,do you hear the fan blowing,if not you could have a bad evap fan motor,also check the back inside wall of the freezer,you might have to pull the second from the bottom bin out and touch the wall and see if it's iced up or if there's frost on it,if so you have a defrost problem,let me know what you find and send the model number ,open the fridge door,on the right side up near the ceiling you'll see a tag with the model and serial number,i just need the model number and i'll be glad to help you
Oct 31, 2010 | Kenmore 57066 Side by Side Refrigerator
Frigidaire FP120V Fridge is too warm, yet freezes in crisper
There may be vents that need to be closed and or opened a little for proper adjustment.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Fridge problem
hi
is this a frost free fridge if so then it is possibly not defrostingand has built up to much ice in the evaperator
cheers grantsreps
Sep 29, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
