Question about Paradigm Atom Speaker
Extreme rattle in the speaker. where can I get it repaired in the Bay Area. I'm in the 94517 area code.
Rattling noise
Ed, that is a tough one to diagnose from here, possible bad U joint on drive shaft, loose exhaust baffle if in the area, best to take it into a reputable shop and have them diagnose and estimate repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 27, 2016 | kawasaki Motorcycles
Sound is muffled
This may be exactly how it was designed, large TVs are usually made to be connected to a sound system or sound bar to get decent sound.
Check that there is no dust in the speakers, when sound is up slap the speaker area, if you hear a rattle or any change there may be dust or dirt in the speaker area, use a vacuum cleaner to remove it through the speaker grille.
Dec 15, 2013 | Sanyo Televison & Video
Rattling in engine bay
check your belts and the bolts around that area, sounds like loose bolts causing something to move and rub
Aug 05, 2013 | Vehicle Parts & Accessories
Zip code pasay city
Location ZIP Code Phone Area Code
Domestic Airport P.O.
1301
Manila Bay Reclamation
1308
Pasay City CPO - Malibay
1300
PICC Reclamation Area
1307
San Isidro
1306
2 San Jose 1305 2
San Rafael
1302
San Roque
1303
Sta. Clara
1304
Villamor Airbase
1309
Aug 11, 2011 | Computers & Internet
I want to disconnect the factory sub-woofer from the factory radio.
generally the speaker cover panel will 'pop' off with a little gentle prying, giving access to the speaker itself which will allow you to simple pull the wire leads. I would suggest taping them so they don't cross and cause hiss in your system or rattle inside the speaker containment area.
Nov 13, 2009 | 2001 GMC Yukon XL
When i play certain bass, like mainly highs, but not all highs, my speaker seems to rattle. no im not an idiot. i know subwoofers rattle stuff when you have them on. i know almost all there is to know...
It is possible to overdrive a speaker beyond what it can handle.
DO NOT BELIEVE the spec sheets regarding power and capabilty, especially those for automobile amps and speakers.
If the cone moves too far, the voice coil leaves the active area of the magnetic field and the speaker will "rattle".
The speaker AND its enclosure may be resonating at particular frequencies.
If these things are happening, you will permanently damage the speakers.
Jul 29, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Rattle under the front end?
The rattle may be stabilizer link rod bushings or a strut mount loosening up as for the engine light you must hook up a code reader to determine the problem otherwise you may be replacing parts blindly.
Jul 10, 2009 | 2002 Ford Escape
Rattle in rear os boot area
Hi John
If it has only materialized since the shunt, and the associated repairs, I suspect this is the area to look in.
Possibly, they have not adjusted the boot lid lock striker correctly, and this being a little on the loose side, is giving the rattle ?
Normally if you get a grip of the boot lid, and jiggle it up and down, you can hear a rattle.
Also check that the exhaust has not been shunted forward, and is fouling somewhere, as this will give you a rattle too.
Good Luck !
Give me a FixYa rating please....... I want to be a Guru !
John.
Feb 04, 2009 | 1998 Jaguar XJ8L
Brakes
you need to go to an engineer and tell him your brakes are making that sound
Jun 06, 2008 | 2003 Volkswagen Passat
Rattling at high sounds
yes buy new set those sopeakers cant take it unless your on arattle area but if speaker does if u can open it up cheak screws tight or not take it back buy samsung x40 c50 way nicer sound ok
Jan 16, 2008 | Sony DAVHDX265 System
Paradigm Atom Speaker Logo
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
