Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motorola k1 not formatting memory card
If i am formating my memry card bt is is giving "format failed try again" n when i put this card in other sets it works fine.it is nt working only in my set.
  • tarai Aug 07, 2008
    I bought 2 Gig Memory Card and loaded some mp3s in it through a memory card reader but if i insert the memory card to my razor phone, it says it is not formated, and im trying to format it but it can't. But if i use a memory card lower than 2 gig, it works.. Why does my 2gig memory card cant push through?
  • 103 Answers
This may be because your phone does not support that ype of memory card. get another one and see if it
Posted on May 13, 2008
I have 1gb m2 memry card for about a year it
this happens dude.
try to format it using a memory card reader on a computer, sometimes the card get corrupt
format it, it shld work fine, u can copy ur data also on the computer for a backup.
Nov 02, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
which hand set ur using? and try 2 empty few space so that it should run in ur hand set
May 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card is nt formatting
You need to try reflashing the phone firmware this should correct the issue
May 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 is nt reading memory card
try 2 format in some other motorola set and then put it in ur handset. its ur hardware problem that says remove card when u close ur cover try take it out ur memory card and then u watch it says same?
Motorola k1 not reading memory card
Motorola phones often require memory cards to be formatted in order to be used. Go into your Setting and Tools menu. From there it depends on which carrier you have and which version of their software, but you're looking for an option for Memory or Storage Devices. It may be under Device Info, Phone Info, or another similar header. Again, the exact menus will vary between carriers and software versions.
Once you locate the menu for Memory/Storage Devices you should see an option for the Memory card. Select it, then choose Options (right soft key) and you'll see the Format option.
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Dec 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola KRZR K1freezes with SanDisk 2 GB Memory Card - Micro SD.
You have a option in the memory card settings to format. It will format, but still after loading some data into memory card the mobile starts freezing again, even im suffering with the same problem for a long time
Dec 25, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card problem with motorola v360
Try to format it via a memory card reader by your computer. Good luck!
Sep 13, 2007 | Canon PowerShot A95 Digital Camera
SD Mini card
The best way is to do it through your computer
Sep 10, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
