Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Short Protect Problem
Hi, I'm having the same exact problem on my 55". So where you able to solve the problem. Can you tell me exactly what I need to do. I'm handy, but I have no idea what to do here with Caps, diodes and what now. Is it worth it to have it fixed?
    Problem Solver:
  • 7 Answers
The problem is usually a failing or faulty DM board which can be fixed with replacing the 4 bad capacitors...OR...if you cant solder it yourself, a repair facility may charge 250.00 or so and takes about a week turn around time.
The other option is buying a replacement board either from Sears or Mitsubishi from 350.00 and up.
Hope you have good luck. If I can help anymore, let me know.
-MetalDad (Richard)
email: PentiumDreams@aol.com
Posted on Jun 14, 2008
Password protect.I forgot it.need to know hoe to do a hard reset
call tech support thay can tell you exactly what to do.
Nov 09, 2013 | Tablets & eReaders
Philips LCD HDTV
The unit is trying to start and can not. It then enters protect mode. This means that there is a problem and a full turn on would further damage the set. It should be blinking a code, this code will tell you what the exact problem is. If you call Philips at 1-888-PHILIPS, they can tell you what is the exact problem.
To figure out the code, count the number of blinks.
If you need further help, please ask, but I can't tell you what to exactly replace without more information.
Thank you and have a good day.
Please don't forget to rate this solution
Apr 07, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Shuts off after turning on code blinks 2 and 2
2,2 is short protection and means one of two pico fuses is blown and the problem is in the convergence circuit.
I am available as a paid question attention SD TECH and have start to finish step by step instructions for this repair in this model.
Instructions tell you everything you will need and exactly how to do the fix.
SD TECH
Sep 20, 2011 | Mitsubishi WS-55809 55" Rear Projection...
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
I have kenwood car stereo.it shows protect mode..soo what is the main problem? wand what is the solution? pls help
Hi, the unit enters protect mode when the output impedance is too low causing the power transistors to draw too much current. A short may be internal or external to the head unit. The thing to do is first disconnect the speakers to see if the unit will come out of protect. If this does not work, the short is internal, and the head unit must be repaired or replaced. If disconnecting the speakers DOES resolve the short, then the speakers and wiring must be checked for a short. The easiest way to do this is to use an ohmmeter at the speaker connector. Check the impedance of each pair of speaker wires. The impedance should be between 4-8 ohms. Anything less than 4 ohms may cause the unit to protect, depending on the exact design of the unit. If you find any wire pairs to have less resistance than the others, access the speaker to check the impedance of the speaker alone. If the speaker has an impedance of 4-8 ohms, the problem is a shorted wire. Please let me know if you have questions, and thanks for using FixYa.
Mar 20, 2011 | Kenwood KSC-310CCS Center Channel Speaker...
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
I need to download the program for windows 98
exactly....tell me what exactly you need......
Mar 17, 2008 | Computers & Internet
Legacy amp 1200 watts
i have had the exact same problem with the exact same lagacy amp that you have posted, put your ground in a different spot or try double grounds in two different spots this should solve your problem here. good luck
Oct 06, 2006 | Legacy Audio LA770 Car Audio Amplifier
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
