Question about Kitchen Ranges
I used oven cleaner on my self cleaning oven. now it wont heat up what did i do?
  • Kitchen Ranges Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 02, 2010
The oven door wont release after self cleaning
Check to see if a spill has glued the door shut from the heat of the cleaning. Remove it with oven cleaner. Some devices have a timer that waits for a while before releasing the door. I had a front load washer that did that, very exasperating.
Sep 24, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
On the self cleaning option of the above, error f02 appears and the cleaning wont start. Its a pyrolitic self cleaner, apparently and about 2/3 yrs old
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Ovens
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
    HELLO,
    Please carefully apply the below instruction to clean up your range
    self cleaning solution
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    The oven was cleaned with oven cleaner instead of using the Self-Cleaning operation. Is it safe and should we be worried about any problems.
    It is safe to use. Make sure you let it run for about 20-30 minutes at 350 before putting any food in it, this will burn off the residue. Also before starting it make sure you didn't get any cleaner on the heating elements if so wait for it to evaporate before using.
    Mar 05, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
    You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
    Oct 08, 2009 | GE JGRP20 Gas Single Oven
    What do you do after you run the oven through the cleaning cycle?
    just brush out any crumbs or large food spills the best you can[.try not to scrape into the ovens paint coating]the rest will turn to ash from cleaning and you can sweep that out also.after cleaning if you what to use a lite cleaner you may,just wipe out well with water so when oven heats up you have no chemical smell on food.also some manufactures advise to remove racks so wont bend from heat. God bless ,tom
    Feb 01, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
    Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
    If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
    To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
    May 04, 2008 | Kitchen Ranges
    Hotpoint self-cleaning oven
      I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
    Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
    Kitchen Ranges Logo
    153 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
