Question about Poulan Garden
No spark to plug on the WEED Eater Featherlite 25 HO SST. Coil looks good. Conncetions to stop switch good. What am I missing?
  • 183 Answers
Make sure you are testing for spark with an inline spark tester. This type of test will connect between the spark plug lead and the plug itself. If no spark, then disconnect the wire(s) from the ignition module...don't just disconnect them from the switch. Now retest. If still no spark, then the ignition module (coil) is faulty and will have to be replaced. If there is spark with the wires disconnected, then there is a short in the wires leading to the switch or in the switch itself.
Posted on Aug 31, 2010
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
Weed eater won't start. changed spark plug,
possibly on/off switch-has it gotten wet? Also check where wiring from on/off switch meets the wiring from the weedeater body.Check those connectors/crimps make sure theyre plugged in /right fit and not wet.Make sure youre ground wire is grounded/attatched/screwed to the machine.Ive had a weedeater get wet twice at the on/off switch and had to bring it in the A.C. overnight to really dry out.It worked.Hope this helps.If none of this does then its maybe the coil(semi-internal-no fun) or the fat wire carrying the spark from the plug to the body(semi-internal-no fun).Good luck!
Jun 28, 2010 | Garden
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I have a weed eater blower bv1085, It just stopped. I have changed the fuel filter, air filter and plug but it still will not start any suggestions
Put a spark tester on it see if you have spark,if not.its your coil,would probably be cheaper to buy blower at yard sale than buy a coil. If tou do have spark order a rebuild kit for your carb.When you take the carb off and clean it,look real close,there will be a number on the carb,you need that number to order the right kit,all carbs on weedeater brand equip. are like that.
Aug 01, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
314 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
