Question about Kenmore Dryers
I have a Kenmore dryer and the belt broke. Opened the dryer and can't figure out how to put the belt back on and there is a wheel that came off and not sure where that goes. Looks like the belt may go around the big wheel, but where does the white wheel with the clip go.
  • Kenmore Master
  • 43,501 Answers
Here is the diagram that you need to get that belt on your dryer..
Kenmore Dryer Belt Diagrams and Replacement
heatman101
Posted on Sep 04, 2010
Opened my kenmore 80 series to replace belt and found an arm with wheel laying at bottom.Trying to figure where it belongs
Hi and welcome to FixYa. I am Kelly. Use this link and look at figure 11 for proper routing.
http://repair2000.com/wpoolbelt.htm
If this is NOT fitting to your model of dryer please provide the model number and I will provide you with the routing diagram.
Thanks for choosing FixYa,
Kelly
Aug 16, 2010 | Dryers
Dryer won't turn on
touch the door swich and see if it clicks when you push in on it,if that is good you'll have to check thermal fuse that is located either on blower wheel housing or in back of dryer,check to see if belt broke some dryers have switch that kills dryer if belt breaks
Nov 03, 2009 | Kenmore 73932 Gas Dryer
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Putting dryer belt back on
The piece you see is called the idler pulley. Here's a link to a good description of how to change a dryer belt. It should show you what you need to do set it all right.
Nov 26, 2008 | Kenmore 62872 Electric Dryer
My belt fell off and im trying to put it back on however all I see is something with a wheel and I can't figure out how to secure the belt.... any ideas?
thats the idler wheel..put booth sides of belt coming of drum between that idler bracket the on the motor pully..onthejob
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Dryers Logo
276 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
