Question about Kenmore Refrigerators
It makes a loud noise when it stops running. - Kenmore Refrigerators
  • mbolster Sep 08, 2010
    Why would a tech replace the compressor for no charge? Who should I call to check it out?
    I hope I can find a knowledgeable one.Thank you.
  • 2,382 Answers
Hi, what is probably happening is caused by a broken mounting spring inside the hermetically sealed compressor housing upon which the electric motor sits. If one is broke the motor will bang against the sides of the housing when it shuts off. Nothing you can do about it because you need a tech come out and verify the problem and if it is what I suggest it shouldn't cost you nothing to replace the compressor.
Posted on Sep 08, 2010
  • Tunde Autos
    Tunde Autos Sep 08, 2010
    Hi, it was a typographical error. the tech will definitely charge you for his service and make sure get a qualified refrigerator tech to replace the compressor
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Loud noise when stops ''running''.
the noise your hearing  is a weak spring in the compressor. what happens is the compressor is a motor inside of a steel shell that spins at high rpm's when the unit shuts down and as the compressor starts to stop the weak spring is allowing the compressor motor to bang against the steel shell. around here we actually call these "Bangers". anyway the fix is obviously to replace the compressor. but considering the age of the unit you may want to move it to the garage and buy a new one for the kitchen.
Btw in my experience this does not interfere with normal operation of the unit it is just annoying. If I can be of further assistance please ask thanks Peyton
Posted on Mar 06, 2009
Engine making loud noise when running I removed the serpentine belt and stop?
Turn all the pulleys by hand. Chances are you will be able to tell if there are bad bearings in cone of the following: Power steering pump, alternator, idler pulley, A/C compressor. The one that is failing will probably feel rough when you turn it or have a lot of play in it.
Sep 26, 2014 | 2004 Honda CR-V
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
1995 GMC SONOMA makes a loud sqeaking noise when i take off in the first to third gear, after third gear it stops, but when i get to a stop sighn it starts all back over, loud noise.
This type of noise is likely to be a universal joint that is worn out in the drive line. have a shop put it on a lift and inspect the joints.
Jun 06, 2012 | 1995 GMC Sonoma
My airconditioning was on and then started making a loud noise
FROM YOUR DESCRIPTION IT SOUNDS LIKE THE A/C CLUTCH ON YOUR COMPRESSOR IS GOING BAD. U EITHER HAVE TO GET CLUTCH REPLACED BY EXPERIENCED COMPRESSOR REBUILDER OR REPLACE COMPRESSOR AS A WHOLE
May 06, 2012 | 2003 Buick Century
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Refrigerators Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
