Question about Acer AL1916W 19" LCD Monitor
How to turn off anti theft - Acer AL1916W 19" LCD Monitor
  • 6,831 Answers
Hello
OK, hold down Menu switch while switch screen off- enjoy.
Kind regards
Andrea
Posted on Aug 31, 2010
99 explorer alarm disables. Motor dies
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
Aug 17, 2016 | Cars & Trucks
My anti theft light is on and my car won't start
try to start the car then leave the ignition on for exactly 10 minutes then turn the key off(anti theft will stop flashing). and try to start it again..... might take three tries
Dec 10, 2013 | 1996 Chevrolet Cavalier
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
Mar 13, 2011 | Acer G185HAb 19" LCD Monitor
Car won't start.Theft light blinks,clicking sound under hood and thumping like horn wants to go off.Seems like it's stuck in anti theft mode
anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter The perimeter anti-theft system consists of the following components:
  • anti-theft indicator (THEFT)
  • remote anti-theft personality (RAP) module
  • hood switch
  • keyless entry remote transmitter
  • deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
  • Are programmable.
  • Must be set at the same time.
  • House four buttons.
  • House three buttons (Mexico Anti-Theft System only).
Programming
Refer to Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
  • Hood switch.
  • Deck lid ajar switch.
  • Keyless entry remote transmitter.
  • Power door lock switches (LH and RH).
  • Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
  • Power door unlock relay.
  • Power door lock relay.
  • Liftgate unlock relay (Wagon)
  • Park lamps relay.
  • HORN relay.
  • Dome lamp.
  • THEFT indicator.
  • Deck lid release.
Arming
The anti-theft system can be armed if:
  • The ignition switch is in the OFF position.
  • The panic alarm is off.
  • All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
  • The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
  • Pressing the unlock or panic button on the keyless entry remote transmitter.
  • Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
Nov 06, 2010 | 1999 Mercury Tracer
Resetting the anti theft system
Place key in ignition, turn to ON position. (do not start)
Leave in ON position for EXACTLY 10 minutes.
As SOON as the anti-theft light turns off, then IMMEDIATELY start the car.
Then anti-theft is now reset.
Aug 12, 2010 | 2003 Buick Rendezvous
My theft light is flashing but my 1997 expedition wont start.The vehicle turns over but just don't start.
ANTI-THEFT SYSTEM Passive anti-theft system
Your ignition key has a unique imbedded transponder which engages engine electronics and allows the vehicle to be started. Without the use of your special ignition key, the vehicle will not start.
During each vehicle start, the coded key is read by the anti-theft system. If the key’s ID code matches the code in the anti-theft system, the vehicle is enabled to start.
Anti-theft system
Briefly illuminates when the ignition is turned to the ON position to verify that the passive anti-theft system is operating properly.
Also, its possisble that tou have actovated the fuel pump switch.
CHeck it.
Jul 20, 2010 | 1998 Ford Expedition
Starter won't turn over, could it be due to anti-theft or theft deterent system? What can i do
If the anti-theft light is flashing then it is in theft mode. If this is the case turn the key on and wait 1 hour then cycle the key to see if it starts if it does you have a anti-theft problem see dealer. sorry.
Aug 02, 2009 | Chevrolet Monte Carlo Cars & Trucks
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Apr 10, 2009 | 1997 Ford F150 Regular Cab
Anti-theft
if the vehicle starts then stops and the anti-theft light is flahing you may need to re-set the pass-key system to do this you will need to atempt to start the vehicle and when it stalls leave the key in that position and watch the anti-theft light. it should flash on and off for about 5 to 10 minutes. when it stops flahing turn the ignition to off then try to restart your vehicle
Mar 19, 2009 | 1998 Pontiac Grand Am
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
