Question about Acer Aspire 3680 Laptop
I have an aspire 3680 2682 with vista home basic 32 bits pre installed on it, in vista it already had the hard drive divided in two partition and i tried to install xp on the second partition, now the problem is that my pc boot with xp directly, when i press f8 to select vista it does not appear
  • 6,831 Answers
Hello
OK, the problem is that you will need to install the older operating system before you install the new one, you have done this the wrong way around.
If you do it correctly, you will have a boot menu which will let you choose from which system you want to boot.
Kind regards
Andrea
Posted on Aug 31, 2010
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Hi!... I am using window 7 ultimate 64 bit. I am facing the problem of full HD. earlier when me using window Vista that has been ok. If there is any solution plz let me know!.. thanks Moiz Raja
windows 7 os requires atleast 16GB avilable space while windows vista requires atleast 15gb. It could be true that your system requirements are not sufficient for the new os you want to install
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • DVD-ROM drive
If you want to run Windows Vista on your PC, here's what it takes:
  • 1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
  • 40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
  • Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
  • DVD-ROM drive
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | HP w1907 LCD Monitor
I have i dell inspiron 1525 but its operating system (vista basic 32 bit) corrupted. how and where can i get a free download of vista basic 32 bit because i dont have the original disc, so that i can...
Hi!
You can try using the recovery partition of the hard drive of the computer, if the recovery partition is still alive, it will let you reinstall Vista back, you can inititiate this by pressing CTRL + F11 key whhen you turn on the computer. There will be no idication of recover on screen instead it looks like windows is startin to startup recovery. In the window you see below the active startup recorey there is, in blue, something like advance recory or something like that. When you press it you will see dell factory recovery. Hope this helps.
Apr 15, 2011 | Dell Computers & Internet
If i erase my hard drive will it remove all traces of infections on my computer and can i install windows7 instead of reinstalling vista
Hello, Yes if you reformat your hard drive, it will remove any virus software that would be on it. Windows 7 have a recommended minimum pc configuration. Make your pc is up to those configurations.
  • 1 GHz processor (32- or 64-bit)
  • 1 GB of RAM (32-bit); 2 GB of RAM (64-bit)
  • 16 GB of available disk space (32-bit); 20 GB of available disk space (64-bit)
Hope this helps
Jan 30, 2011 | Acer EXTENSA 54205038 COMPATIBLE LAPTOP...
HI ! My name is Vinod. I hava Compaq Presario V6604 AU 2007 model. I am using dual booting system in my laptop with windows vista home basic and windows 7. My laptop came with windows vista pre-installed....
I know of problems running Vista and Win7 from the same hard drive and it is usually fixed by having Win7 as the main boot on "C" and Vista on "E" a separate partition.
The sound drivers are very similar and usually only give trouble when mixing 32 bit with64 bit.
Hope this helps
Dec 24, 2010 | Compaq Computers & Internet
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Dec 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
Can i install to windows vista
you can install Windows Vista if your computer meets the following standard requirements:-
DVD-ROM drive
Audio Output
Internet access (Optional)
Hope this was helpful.
Cheers!!! Have a nice day!!!
Sep 14, 2010 | Computers & Internet
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Vista on my toshiba laptop not updating,
Check your processor, hard disk, and memory / graphics
against this list.
Recommended minimum hardware requirements for Windows Vista loadTOCNode(2, 'summary'); The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements will vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required. Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • 32 bits per pixel
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
You can download a free and updated virus scanner here.
You can also acquire a free trial (recommended) of asquared
anti-malware here. Run a "DEEP" scan with a2 free.
Nate P.
Jan 25, 2009 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 3680 Laptop Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
