Question about Vacuums
I have a window fan with two fans in it & I cannot get the cover or back off so I can clean it. I* have taken all the screws out that I can get to , but there are two clamps that I can't get off, I'm not sure why the clamps are there but they are on the side with the accordian extention. Please tell me how to get it apart - after 2 years it is really filthy!! Thank you, Janet
  • janet723 Aug 31, 2010
    the solution "Guru" gave was useless, I have already done that, I want to clean the fan blades & INSIDE the casing.
  • 11,896 Answers
Remove all the screws, pry clips off that hold on the extensions, than fan will pull apart. The clips must be pried off. They will not break. Then remove screws holding in the fans and remove them as well. Fairly simple process.
Posted on Aug 31, 2010
  • 43,501 Answers
Hi Janet,
I feel you pain and I tried to do the same thing once...now I have taken many things apart and these things frustrated me to no end....
What I eneded up doing was to very carefully spray everything down with a soapy water solution from a spray bottle....letting it soak a bit and then taking the sprayer from the sink and rinsing eveerything off being careful not to get the water in the fan motors...
While this give not give me quite as good a cleaning job as I would have liked it did help out alot...and seems to be the best I could do without breaking things....
Seems as though they really don't expect them to last long enough as to have to clean them...:-)
heatman101
How to remove CLOG Riccar RAD.7 vacuum?
There is a clean out port on the back on the lower portion. Remove two screws to remove the cover to gain access to the air path from the floor to the bag. If this doesn't solve it you may have to remove the screws on the bottom which allow you to remove the cover of the nozzle assembly. There is a cover that goes from the floor to the direct air motor. Remove the screws to remove this cover which gains access to the air path and fan of the direct air motor. It's possible you may need to remove the direct air motor to clean out the fan if it has something stuck in there. This is not a job for the average person but if you are very mechanical you should be able to do it. If in doubt take it to your dealer. It is not very expensive to have done.
Apr 22, 2016 | Riccar Radiance Upright Vacuum Cleaner...
Remove hoover vacuum fan
I don't know what model you have but on most vacuums you need to remove the nozzle housing from the vacuum, remove the cover over the motor to gain access to the motor. Remove any screws holding the motor in. Remove the motor and take the screws out to allow access to the fan. Remove the fan, replace and put back together exactly as it was before.
Nov 09, 2015 | Hoover Vacuums
How to remove fan from rsl3c ?
Remove the bottom plate screws & bottom plate. Remove the screws holding the motor and fan assembly to the nozzle housing. Remove the screws Holding the fan housing to the motor to gain access to the fan. Remove the bolt holding the fan on the motor shaft to remove the fan.
Sep 08, 2014 | Riccar Vacuums
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
How can I fix my Lasko E20739 tower fan, when the motor stops running?
That fan has an electronic (computerized) control board which sometimes malfunctions. Nothing new there, right?
The problem is that the cost of the repair can excede the price of a brand new replacement, with a warranty to boot.
You may take it to a service depot and get it checked out, provided you get an estimate and this is done free of charge.
May 25, 2011 | Vacuums
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
How to install Kirby g4 fan
It needs to be stripped completly down, if you are confident at doing this then here goes.
It has been a while for me so take your time and some of the steps may have to be completed slightly differently.
Isolate / unplug the machine from the mains
Remove the bag, handle and front roller assembly so you are left with a bare machine.
Remove the rear switch cover - 1 x screw.
remove the top aluminium cover 2 x screws at the back and 2 x screws at the front below the light.
You should now see the motor and tech drive.
Remove the tech drive, tech drive belt and rear wheels 4 x screws below the machine.
Remove the wiring to the motor noting the correct connections for putting back.
unscrew the motor 4 x screws inside (think) and two at the front below the fan aperature.
remove the motor and fan complete.
To remove the fan, note the hole through the fan shaft close to the belt position, this is for leverage when unscrewing the fan, hold the motor shaft, insert a small screw driver or punch through the shaft hole and unscrew to remove the fan.
Re-fit in reverse order.
Jun 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Apr 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Jun 21, 2008 | Kirby Heritage II Vacuum
Eureka High filtration Commercial vacuum fan
One of 2 ways, remove the plate on the bottom, the is a clear cover covering the fan. Just unbolt the belt pulley and remove the fan. If there is no cover covering the fan, then you will have to remove the top, take out the 4 screw holding the motor and turn motor over, then you can remove the fan.
Jan 10, 2008 | Eureka Smartvac 7975 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
