Question about Kenmore Refrigerators
KENMORE MODEL 363.9751510 TOP FREEZER WORKS, REFRIGERATOR NOT COOLING.
  • 2,272 Answers
The first thing to understand is that all the cooling in a conventional frost free refrigerator usually originates in the freezer compartment, just a small portion of that air is circulated through the fridge compartment to cool there. (Technically the opposite is true. Warm air is circulated into the freezer compartment where its heat is removed by the refrigeration process leaving behind cooled air.) In any case, if that air flow is hampered in any way, cooling problems will result. The second thing you need to know is that the compressor (large black dome at the rear of the refrigerator) provides all the cooling ability for the whole appliance. It has to be running in order for any cooling to take place. As long as the compressor is running, the possibilities listed below will need to be checked one at a time. If the compressor is not running or continually trying to start but failing within seconds, clicking and then shutting down, someone will need to look into why. That alone is likely the cause of your cooling problems. There are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed.The Defrost SystemInspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed .
the evaporator coils never go bad or faulty mostly it only stops working if the over load of ice frost gets collected in between the coil and the evaporator fan due to things the coil actually does not get required hot and this makes freezer bit more cold and refrigerator very low cooling or may be hot. also the other air ventilations gets blocked due to evaporator coils stop working .to resolve this issue the only best option is to empty the fridge/freezer unit and unplug the unit from main power out let keep the door open of the unit and leave it for 24 hours this melts all the collected ice in the coil as well as in the air ventilation area. after that clean the inner area of unit with a dry cloth and then plug in the connection and turn the unit ON keeping the temperature at normal settings. then check out after two hours if the unit works proper the evaporator coil was the fault and that got cleared from the unit by defrosting .but if the problem is same as before after two hours when you check then its defrost timer faulty in the unit
now i will explain what is defrost timer .the defrost timer is the part which controls the cooling and defrosting in refrigerator .it actually spins as the coldness in the unit. after the temperature reaches to certain coolness it spins back wards and defrosts .if the defrost timer is faulty it will not spin properly and all cooling and defrosting system of the unit will get misaligned. if the timer gets faulty the cooling will reach till over frost and then the fan the coils in the unit will get blocked due to ice built-up and over current will be exerted by the unit to melt that ice. and in this melting ice procedure without defrost timer the unit stops completely .it can effect any section lower or upper or may be both. so the defrost timer at present needs replacement. its like a mini plastic box . color is mostly black or white or creamish . the cost of timer is near to $40.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 31, 2010
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
lojacksdad
  • 121 Answers
SOURCE: Fridge quit working but freezer works
check to see if the back wall of the fridge is full of ice
if so that is an automatic defrost problem or check to see if your frezzer fan is blowing
Posted on Apr 17, 2009
  • 22 Answers
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
Posted on Apr 25, 2009
  • 103 Answers
SOURCE: bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
Posted on Jun 03, 2009
heatman101
  • 43501 Answers
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Kenmore model# 79573966 - Top Freezer Ice is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Kenmore Top Freezer Refrigerator
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Kenmore Refrigerator 75509 double door top, bottom freezer. Freezer is working, but the refrigerator is not cooling
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore refrigerator (model #253.73752300) quit cooling but the freezer on top still maintains below zero. Why?
heatman101
Apr 29, 2011 | Kenmore Refrigerators
Kenmore refrigerator top works but bottom doesnt get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Dec 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
My kenmore coldspot 72852101 refrigerator not working but freezer seems to be working
heatman101
Jul 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer is working, but refrigerator section is
heatman101
May 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
