Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP Office jet 7310. Had papper jam . Cleaned out paper in cleaning paper jam . thin opaque l1/8 inch 12 in long strip is now hanging off right side behind cartidge . When top is closed the printer says cartidge jam What do I do with the thin strip of "film" that is only attached to the right side . Looks like 2 holess on left side to be attached to something behind paper glide.? Any hoipe for a fix that isn't expensive
  • HP Master
  • 19,396 Answers
Hi.
The thin strip of film is probably the encoder strip. This is the sensor that the machine uses to detect the position of the ink carriage.
Replacing the encoder strip is not a difficult job.See the links below.
Inkjet repair.
Encoder strip.
Posted on Aug 31, 2010
Paper jam in HP photosmart A616. Can see it but can't pull it out as it is too thin and crinkled.
Take a sheet of paper and fold it in two so the top and bottom of the paper meet. Put the folded end of the paper in the printer so it can push the jam through. There are cleaning sheets you can get at office supply stores that are sticky on both sides. They work well getting small pieces of paper out as well as cleaning built up paper dust from the rollers.
Mar 30, 2018 | HP Office Equipment & Supplies
Can I disassemble an hp office jet e609n printer, to clean the inside
Wisdom says no. If you want to clean the paper path easily go to an office supply store and get printer cleaning paper. It is sticky on both sides and will remove paper dust from the pick up roller and all the other rollers inside. It will also clean any leftover bits of paper from jams. Any internal dust buildup will be cleaned too.
Oct 18, 2016 | HP Officejet 6000 E609N Inkjet Printer -...
I have a 7300/7400 HP Office Jet printer....keeps giving false alarms on paper jam. I have done everything the book says. The print cartridges do not return to the right. I love this printer and
there are a few sensors in the paper circuit. if those sensors have some small pieces of paper you will continue to get this error. If you have serious mechanical skills you can try to disassemble the printer and clean every sensor. if not you should go to a specialized service center.
Jan 17, 2012 | HP OfficeJet 7310 All-In-One InkJet...
HP 7310 Cartrige Belt Repair
The right end is connected with an idle pulley on a spring. If you grab the left end and pull it to the left, the spring will strech. This will help to attach the belt to the carriage motor on the left.
In some printers the spring streching is fixed by screw that have to be loosen first.
If you can't reach the motor's weel on the left, you have to take off some parts first.
Aug 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My 7310 indicates a carriage jam. I've cleared all paper and verified no loose paper, dust etc is present and it still reads carriage jam. What should I do?
Inside your printer the ink cartridges ride in the carriage. If you look closely, there is a plastic strip just behind the carriage with closely spaced little lines on it. If the strip gets dirty with dust or ink, you may get that error. Gently clean the entire strip with a rag moistened with water. be sure the entire strip is clean. Move the carriage back and forth to get at all of it. Then see if that doesn't work.
Nov 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Have a HP officejet 7310 with error message that reads "carriage jam" this occured after clearing a paper jam???
You have to make sure you have gotten all the scraps out, and if you put fingerprints on the clear strip behind the carriage, you will need to clean them off with a Q-tip.
Jul 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge jam
can you move the move the ink cartridges from side to side with your hand, either the head cleaning mech has jammed or the carriage has come off the drive belt, either way, its a repair to be done in the workshop, if its even worth repairing
May 11, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Adhesive jam
Some adhesive still on the transfer or fuser. Try a cleaning page, or some manual cleaning with dry towel-paper if adhesive signs are visible on transfer. Do not try fusing unit because very delicate silicone film inside.
If stain are of a single color, (p.es. magenta) you must change this cartridge.
Dec 24, 2007 | HP Color LaserJet 2600n Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
