Question about Makita 12 Volt Cordless Drill/Driver Kit
I cannot see where to connect the power supply! I have no manual with this second hand cordless drill, and cannot see any holes to insert the power supply.
  • 2,176 Answers
If it has removable batterys then you have to install in the charger, but if it has a different type there should be a charging port either on the underside or back of the drill. Let me know the model number and I will be more specific
Posted on Sep 01, 2010
What size capacitor do I need for my 5250 power back brushless generator r
Why do you assume you need a new capacitor? Sometimes you may have to re-excite the windings on the generator which is simple and I'd try it first. Take a power drill, plug it into the panel on your generator and turn the chuck on the drill by hand or use another cordless drill to spin the plugged in drill for about 5-10 seconds. Unplug the drill and start your generator. Chances are you'll produce the power you are looking for.
Jul 20, 2017 | Electrical Supplies
Tip
How to Hot-Wire Test a Cordless Drill Motor
<span><span>The power switch may not be the problem if a cordless drill stops turning on. Sometimes a bad drill motor can prevent the tool from starting, even if the switch is good. </span></span><br /><span><span>To determine the problem, the best method is to remove the switch and then hot-wire the drill motor to the drill's rechargeable battery to test it. If the motor checks out, then it's probably the switch. </span></span><br /><span><span>The steps for testing a drill motor .</span></span><br /><span><span>In addition to tools needed for dismantling the cordless drill, such as a drill/driver, <b>two</b><b> wires</b> are needed to connect the motor wires to the drill battery. </span></span><br /><br /><span><span><span style="text-decoration: underline;"><b><a></a></b></span>Hot-Wire Test a Drill Motor</b></span></span><br /><span><span><span style="text-decoration: underline;"><b><br /></b></span></span></span><br /><p><span><span>1. Remove the drill's battery and dismantle the drill.</span></span><br /><p><span><span>2. Disconnect the wires leading from the switch to the drill motor. Sometimes this means completely removing the switch. </span></span><br /><p><br /><p><span>3. Now that the motor is isolated from the switch, <b>connect </b>one of the <b>motor </b>wires <b>to </b>one of the <b>battery </b>contacts <b>using one of the two wires</b> set aside for this test.</span><br /><p><br /><p><span><span>4. <b>Connect </b>the <b>second wire </b>to the other battery contact. </span></span><br /><p><span><span>(<b><i>Note:</i></b> It does not matter which motor wire is connected to which battery contact. The orientation is not important because it is a DC motor and will only determine which direction the motor spins.)</span></span><br /><p><span><span>5. Hold the motor firmly in one hand, and then <b>complete </b>the electrical <b>circuit </b>between the battery and the motor by connecting the second wire to the the second motor wire.</span></span><br /><p><span><span><b>If</b> the <b>motor does <i>not</i> spin</b> once the second connection is made, <b>then the drill motor</b> <b>is most likely fried</b> and needs to be replaced. </span></span><br /><p><span><span>If the motor <b><i>does </i>spin </b>after completing the electrical circuit, that's a good indication that <b>the motor is</b> a <b>healthy </b>one. If the motor tests out OK but the drill is still having trouble starting up, the problem is most <b>likely </b>caused by <b>a faulty power switch</b>, not the motor.</span></span><br /><p><br /><span><br /> </span><br /><span><span>The power switch will have to be reconnected to the drill after the motor has been tested. It is important to reinstall the switch wires correctly after performing this test. </span></span><br /><span><span>The example drill used in this article has a very simple wiring configuration in its power switch. Drawing a switch wiring diagram is especially useful for switches with complicated wiring configurations.</span></span><br /><br /><span><span>If you're testing your drill's motor, chances are that some kind of part replacement is on the horizon. </span></span><span><span></span></span>
on Nov 13, 2010 | Drills
Tip
How to use an Electric Drill
  • First You need to choose which kind of electric drill you are going to use - the cord or cordless. The one who has a cord attached might limit you because it need to have an outlet.although, it powerful then the cordless drill. On the other hand, the cordless drill can be use anywhere without needing an outlet.
  • Choose the wright drill according to your job. For an heavy-duty project purchase a more powerful drill but remember that it run slower and most of them have a cord attached to them. If you have lightweight jobs so you can use a cordless drill.
  • The safest way to use a drill is to make sure that the materials to are drilling are straight ahead of you or down below you. in additional, in case that the materials you are drilling is hard or thick one, in first use a hole punch to start the hole before the drill.
  • When you starting the job, push the drill slightly. start out slowly, and as the hole progresses, increase the speed slightly.
on Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
I was drilling a hole and my drill blow up with a burning smel
could be quite a few problems, did you overload or stall the drill, did you have adequate power supply? Quick test without knowing the model number and brand can you turn the bit or chuck with your hand? If it is cordless is the battery contacts burnt? If electric unplug and remove the handle halves and look at the armature/field for burnt windings or burnt switch, all which could cause a burning smell and shut the tool down, let me know and I will try and help further.
Dec 21, 2010 | Bosch Drills
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
Compartment door will not shut properly, camera will come on
Drill 2 tiny holes, large enough to insert thin paper clip wire. One hole is drilled in the battery compartment door, close to the sidewall but in between the 2 adjacent batteries.
Drill second hole in battery case by first peeling back the ruberized coating slighty. This hole should be adjacent or sighted in line with the first hole. In each case, allow enough in tact plastic door or case so that it can withstand the pressure of a tightened piece of wire. Insert batteries. Then insert wire carefully tto penetrate both holes. Press down hard on battery compartment door and carefully twist the 2 ends of the inserted paper clip wire to secure the compartment door tightly. The one drawback is that each time you wish to change batteries, you will have to follow the above procedure.Don't know of any recalls on this condition.
Sy25 syfish@aol.com.
Nov 21, 2008 | Nikon Coolpix 990 Digital Camera
Drill hole in China Plate
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Oct 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hammer drills Power supply
There are cordless varieties of just about any type of hand drill, even the specialized hammer drill. These hammer drills work in the same manner as any of the core hammer drills or regular drills. Powered by a set of rechargeable batteries.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Jan 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Makita 12 Volt Cordless Drill/Driver Kit Logo
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
