SOURCE: Ice maker make hollow ice
What kind of ice maker do you have??? Hollow ice can be caused from different things in different machines..
It can be caused by not enough water or by water not flowing properly across a plate...amoung other things...
heatman101
SOURCE: DCE33A-1BC Scotsman Ice Maker will
From your description it seems that the refrigeration system of the ice cube is not cooling enough. For this reason the production per day is much lower than it should be. That is why the unit never stops since by the time it have produce new ice cubes the first ones already melt. So it can never be able the ice been container to full enough to rice up to sensor bar.
So first you should reach for the condenser and with a brush and a vacuum cleaner try to clean it from all the dust on it. This will increase the capacity of the cooling system.
You need also to check that the condenser fan is working since if it don't then you will need to replace it.
If the two above case are ok then you need to check the freon charge and it might need some additional Freon charge, but this is not a DIY job since you will need special expensive tools and also a license to deal with freon.
In any case try the two first cases since are the most possible ones.
SOURCE: ice maker not working and
Hi, If you are hearing a clicking or buzzing then check out the last two tips.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: ICE MAKER RUNS WITH WATER
If the ice cubes are smaller than the normal sized ice cubes
and the shape seems to be irregular, there might be problems with the
water supply. The ice maker could be malfunctioning due to a faulty
water inlet valve. In case, the handle on the valve is not in the right
position, fluctuations in the water pressure could result in the
irregular shape and size of the ice cubes. Ice maker might also not be
able to work due to clogging of the water supply valve. A blockage in
the filter could also obstruct the water flow. You might have to
consider ice maker repair in case the valve contains a bad coil.
SOURCE: KENMORE COLDSPOT MODEL10652212104 THE FAN
Hi, if the fan, evaporator fan is not running, it has failed on you. If you are up to doing this kind of work, you can replace it your self. It is a 120 volt evaporator fan motor, and if you can get it out, take it with you along with the name of the unit, model & serial # to an appliance parts house to get one. If they don't have the exact one, they have universal ones that will fit. This will solve your problem.
Shastalaker7
A/C, & Refrigeration Contractor
heatman101
