Question about Canon MF8180C Color Laser MFC Printer
Can I network this printer through a router - Canon MF8180C Color Laser MFC Printer
  • 131 Answers
Shouldn't need to place it on a router. A network switch will suffice. Just make sure any computers printing to it are on the same network (example: 192.168.5.XXX) where the XXX's change per network device.
Posted on Aug 31, 2010
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
Tring to get PC to send signal to hp printer thru belkin N300 router
  • Hook up printer to network.
  • Give the printer a static IP address outside of DHCP scope. (If your network address is 192.168.0.0 typically any address from 192.168.0.1-50 will be. 192.168.0.1 will usually be your router.
  • Install the printer on computer with appropriate driver and install as a network printer, not local.
  • Enter the IP you gave the printer.
  • Done
If your printer doesn't have networking capability let me know and I can explain setting up a printer share.
Jan 10, 2013 | Belkin Basic Wireless Router
My router cant recognize my printer
It is not the router that has to find the printer but the printer has to find your router and network, so what you want to do is go into the menu of the printer and set it up on the network, this is a built in security feature so that not just anyone can connect to your router with their printer. Hope this helps.
Sep 02, 2012 | Belkin Play N600 Wireless Dual Band N...
I have a D-LINK DIR-625 router. i need to add a printer to the network but not sure how. Someone had told me that the router does not support the additional printer but i dont believe that. Can you please...
If the printer is a network printer connected via wifi or via ethernet you should be able to add it on your network.
If the printer is connected via usb port you will need to have a router that has a usb port and is able to add it on your network.
If the printer is lan (ethernet or wifi) you plug it and search in printer installation for a network printer. To easier step you may want also to reserve to the printer a fix ip address and a network name.
For further information you may want to follow producers instructions. If you don't have the manual you should be able to download it from producers website
Apr 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Missing password and printer connection
are you using internet router for your wireless network? you download software for your internet router or if you want reset your internet router this will refresh your router and give the manufacturer original settings with "admin" user without password.
you can also connect your printer to other computer and share it so that other computer on your network cab use it. just open the share printer in the network and windows will install it or go to add printer and look your printer using network.
hope this will help you.
Nov 24, 2008 | Linksys Ultra RangePlus Wireless Routr...
Network printer
Connect one end of an ethernet cable into the ethernet port on the printer and the other one into a free port on the router. Then, using the install CD, tell it that you are attaching a printer on the network. The software should automatically detect the printer on the network and set itself up for it.
Jun 26, 2008 | Computers & Internet
Canon MF8180C Color Laser MFC Printer Logo
29 people viewed this question
old marine
old marine
