posted by 2531625 on May 09, 2008
i cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Solution #1
posted on May 11, 2008
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother Multi-Function Center
Email this problem
Email this problem
Can you Help with these Printers problems?
Brother Multi-Function Center MFC-240C...
cannot remove black cover
How do I take the black cover... Answer This...
Repair Service
Find Printer Repairman Near You:
