Question about Panasonic KX-TG4500B Phone
Where can you get the A/C Adapter for this phone?
    President:
  • Panasonic Master
  • 860 Answers
You can get another adapter from panasonic's parts website:
http://www.pasc.panasonic.com/epartr/PartslistChoice.asp
The adapter's model number is PQLV256Z.
Posted on Aug 31, 2010
Change dock connector
Though I'm not sure, I think what you are asking is how to use an iPhone 5s on an older iPhone docking station. If so, my recommendation is to buy and a 30 pin to 8 pin adapter. Here is an example:
http://phonepartsusa.com/adapter-30-pin-to-8-piniphone-5-ipad-4-ad?language=en₪cy=USD&gclid=CJbTm_u188MCFUZhfgodt2wA9Q
Apple sells one as well called a Lightning to 30-pin Adapter for about $30. Here is that link: http://store.apple.com/us/product/MD823ZM/A/lightning-to-30-pin-adapter
It all depends on the form factor of your dock and whether the added size of the adapter will still allow your phone to sit on the dock. There may be some smaller, slimmer ones. If the phone doesn't fit on the dock with the adapter in place, you could also buy a iPhone 5s extension cable and just cable your phone to the dock and adapter.
Feb 21, 2015 | Apple iPhone 4S
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Cigar adapter works, won't charge phone
bad charger or not compatiable
Sep 12, 2012 | Cars & Trucks
I have a VTECH 6.0 and I believe a lightning strike took out the telephone base power adapter and would like to purchase a replacement adapter.
Any generic adapter will work as long as is is the same voltage and rating on the wall adapter you have. It is a 6 volt 400MA adapter. Radio Shack has generic adapters. Also try your adapter in another wall socket and see if that works.
Hope this helps.
Dec 13, 2011 | Vtech Cordless 6041 Phone
W810i not getting charged
Hi.
The most common problem is given by the blades in power adapter connector. The metal blade-shaped prongs tend to go backward inside the adapter plug and do not make contact inside the phone socket. If that is the problem replace the adapter.
If that is not the problem check if the adapter has voltage at the phone connector. The contacts that have voltage are the two leftmost when you watch the plug while connecting with the phone display in front.
If the adapter is OK, then the phone socket is either oxidized or damaged inside.
Regards.
Ginko
Jul 19, 2011 | Sony Ericsson Walkman W810i Cellular Phone
Lightning stike over house and now base unit won't work. Phoen line is okay. Want to see if it is the power adapter. If so, can I buy a new adapter instead of the whole phone unit?
yes you can get an adapter seperately but it depends on which phone you are using.
you can also buy china makes of your adapter at very low price.
But if you prefer to go with quality not price then you can go to any of the service shops of your phone's company and buy a new adapter from there.
Feb 11, 2010 | Uniden Cordless Phone
My Nokia 5610 music phone got password protected
If you have a Memory Card adapter slide the micro sd card into the adapter, and make sure the slider on the adapter is NOT in the lock position. If you do not have an adapter put the sd card in the phone and then go through all your memory settings and make sure you dont have it locked through the phone. Hope this helps!
Jun 08, 2009 | Nokia 6300 Cellular Phone
Motorola W755 2.5mm headphone adpater connectivity problem
It actually has to do with the 2.5 mm adapter. I had the same problem and went to buy a new one because I thought the adapter was bad. Went to Radio Shack and the guy said there are 4 wires within the audio input so that you can add a microphone too if you want. You have to buy an adapter that grounds that 4th microphone wire and it'll work just fine. I got the more expensive adapter (about $10) and haven't had the redial problem since.
Dec 22, 2008 | Motorola Mobility MOTO W755 Cellular Phone
My phone does not support the data enhancement
i have the cable adapter which is ca-62. but when i connect my phone with my pc then pc shows that it is an unknon device. so what should i do?
May 23, 2008 | Nokia 6020 Cellular Phone
No dialtone
It just sounds like the problem with the phone itself. try with the diffr phone and phone cable. If it is a cordless phone, try with the corded phone.
If you have spliter or homewiring, please isolate them and connect the phone directly the phone adapter.
- To check whether it is a phone problem, remove your phone from the phone adapter and make sure phone light on the phone adapter is solid, then make a test call from your cell phone to your phone, you can hear ringback tone on your cellphone which indicates your phone line is actually working fine. After that connect your phone back to phone adapter and check the phone light status whether its blinking or no light at all. make a test call to your phone, call may go to voicemail or may give busy signal. So it could be phone trouble.
- You may also call techsupport and ask them to assign the phone number to phone port2 ( phone adapter has 2 phone ports, by default, line assignd to port1 ).
- If your Online account has a facility to move a number from port1 to port2, you can try it.
- Laxman
Nov 24, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Panasonic KX-TG4500B Phone Logo
46 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
