Question about Microsoft Xbox 360 Console
Error i opened slide and put in game, after a few seconds got a red flashiing light along with a page of jiberish in other languages also E 73. please help just played it the other day!?????
  • Twister420 May 09, 2008
    I put the game in and after a few seconds a message appears appears stating: "TO PLAY THIS GAME PLEASE INSERT INTO AN XBOX 360" ????? THEN IT SAYS IT IN DIFFERENT LANGUAGES. After a few restarts thought and a slight touch of the hard drive it works with no problem..It is verry irritating, how do i fix it??
You probably have a general protection error. Call microsoft's tech center. They can tell you what the code means and if you need to send in the console for repairs. Since they extended the warranty on the system, most repairs should be free.
Posted on May 09, 2008
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
It wont eject and it comes up with error c32
You should be able to solve this yourself. ... ... Just as I though. Just remove your battery, and unplug the power cable. Wait a few seconds, and put one or the other (or both) back in, and it should work.
I think what has happened, is the door got jammed when it was told to open, but it got stuck. If this doesn't work, please refer to your operation instructions (pages 73-76)
Jun 06, 2009 | Sony Handycam CCD-TRV65 Camcorder
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
I have an one red light problem and error 73. Don't use ethernet
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm This should help you, I repaire these all the time and as soon as you get rid of those x-clamos and use the screw and washer set it fixes this problem. My name is Tim Ehrhart and I hope this helps you
Mar 15, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Error e 73
Do not ever use a heatgun on your system it will damage the mainboard and if it melts the solder under the GPU you will need to send it out to get the chips removed and reflowed which is probably more then getting a new one.
Jan 19, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
