Question about Car Audio & Video
I replaced the battery. now it reads off. i need a 4-digit code.
  • 864 Answers
This is the security code its usually located in the glove box or if its an aftermarket stereo it is written in the manual provided. If you have lost it you will have to give me the make and model and from there we can see if there is a way to reset it so you can enter a code. But if its like a alpine or pioneer that would be bad cause they are individual codes. an you would have to contact the manufacturer. Thanks, Midwest-tek
Posted on Aug 31, 2010
My 2005 Honda pilot had battery disconnected then read code and now says error? I tried putting in radio code still error?
Sounds like you have the wrong code, maybe the radio was replaced? Hold preset buttons 1 and 6 then turn on the radio. It will display the radio serial #, 4 digits then 4 more. Dealer can get you the code. Or you can register at the owners site online and get the code yourself.
Jan 25, 2015 | 2005 Honda Pilot
I have a Blaupunkt Cambridge SQM 39 car stereo. I replaced my battery and when I turned to the unit back on, rather than saying 'code' across the screen, it just has 4 lines. I have read the manual and...
Hi, think the solutions 1 and 2 didn't match your problems. You have to at first reset by, turn on the radio and wait for half an hour or more until the text "code" appear on the screen. Then you can enter your code. You have to press the "PS" button when you enter the keys 1 to 4. God luck. I had the same problem but this procedure helped me.
Apr 02, 2011 | Car Audio & Video
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
My 2680s-2 still needs a security unlock code,have tried using 12345 but to no avail,my IMEI IS 358309/03/829483/4. PLS assist me get it unlocked!
Tounlock cell phone Password:Instructions
Enter the last four digits of your phone number on yourcell phone PIN screen. Enter 9999, and if that doesn't work try 1111, and ifthat doesn't work try other 4 digit numbers you may have entered. Shut off your cell phone, take off the back of your phoneand pull out the battery. Record the IMEI number which is under the battery.Re-insert the battery and power on the phone. Enter the last 4 digits of theIMEI number on the PIN entry screen. Callyour service provider and request the unlock PIN. You will have to prove youare a customer by stating your cell phone number, addressand social security number. Turn off your phone. Hold thekeys "3," "*" and "Call" and switch the phone on.Hold the three buttons down until the word "Formatting..." appears onthe screen. This should reset the phone lock code. Read more: How to Unlock a Cell Phone Password ' eHow.comhttp://www.ehow.com/how_4810931_unlock-cell-phone-password.html#ixzz19YU6TIa2
Dec 31, 2010 | Nokia 2680 Cell Phone
Need to reset my intermatic inc security alarm model number sp130b
It is very simple to reset your Intermatic SP130.<br /> <br /> 1: Remove SP130 from the wall/door by lifting upwards about 1/4 inch.<br /> 2: Remove the battery cover and one (1) battery.<br /> 3: Decide on a four (4) digit code. You must enter your desired code within 5 seconds of reinstalling the battery.<br /> 4: Reinstall battery and immedately enter your desired 4 digit code.<br /> 5: Reinstall battery cover and remount to wall/door<!-- from fixya rte -->
Aug 13, 2010 | Intermatic SP130B Wireless Door/Window...
Accord EX 2006...changed battery. I have the key
the radio code is a 5 digit code and the navi is a 4 digit code. if it continues to read incorrect pin then you may need to see your local honda dealer to get the correct pin
Nov 09, 2009 | 2006 Honda Accord
Dead Battery equals Stereo lock
You must get the 4 digit security code and enter it into the radio by pressing the AM and FM2 buttons at the same time. Then enter code via the preset buttons. Press button #1 until you get the first digit of the code then press button #2 until you get the 2nd digit and so on for the 3rd and 4th digits. when code is on the display press the AM and FM2 buttons again and radio should come back on. if it reads safe you have the wrong code #. You can get the code from a dealer for a small fee. They need to remove the radio to get a serial # on the radio chassis.
May 27, 2009 | 1998 Audi A6
The odometer reading disappeared on my '98 Volvo S70.
Have you found anything out. I brought my volvo in to have the battery replaced and when I picked it up I noticed the odometer was blank (no -----) just blank. I was told it was not related and probably just a bulb. Not a bulb I have no idea. I don't want to replace the cluster unless I'm sure what have you found out. (all my other gauges are fine speed, tach, trip fine)
Jan 20, 2009 | 1998 Volvo S70
No passcode
Open the battery compartment and look at the codes underneath the battery. There will be two codes:
C1234 ###
B ####
It is the second code which is your pairing code.
Oct 27, 2007 | Nokia HDW-2 Consumer Headset
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
