Question about Minka Aire Ceiling Fan
I have a Kenmore Ceiling Fan Remote Model Number R520T Three Speed, Reverse, On/Off Is there a direct replacement available so i dont have to get to the fan to install anything. Fans are 20 off the ground.
bigg t
  • 640 Answers
SOURCE: Ceiling Fan
the start switch is bad.if you open up the fan you may see a little black looking box thats the switch.if not the switch is on the motor itself.an electric supply warehouse may have the part.
Posted on Sep 01, 2007
Pranavendra
  • 16 Answers
SOURCE: 3 speed ceiling fan
I could not understand that "all the three positions are on high speed and off" ? How can be it possible that all the (three) positions give high speed and at the same time no speed (off)? Please explain.
 What I feel that the speed controller be in series with the fan. "in series" mean that the wire should come from phase or line, go to the speed controller , then go to the fan, then finally go to the neutral point. This completes the circuit.
 I will be happy to know more about this if it could not solve your problem.
Posted on Nov 29, 2007
red54eyejp
  • 25 Answers
SOURCE: how do you reverse the direction on this model of ceiling fan
SHOULD BE A DIRECTION CHANGING SLIDE SWITCH ON THE MOTER AREA OF THE FAN...
Posted on May 10, 2009
  • 125 Answers
SOURCE: Ceiling fan won't blow any air
if its turning its either sucking or blowing air. There is a switch or a pull cord to reverse it. prove it to yourself with something light like a feather or piece of paper or balloon.
Posted on Aug 16, 2009
Testimonial: "My fan has the blade tilting backwards and I did not realize that."
SOURCE: reverse
Do you want to sell your Covington Ceiling fans? I may be interested in purchasing them. If you live in Atlanta, I could remove the old ceiling fans and install your new ones if you need.
email me at:
myatlhomes@comcast.net
Posted on Sep 16, 2009
How do I find a new remote for my Kenmore ceiling fan, the remote model number is R520T
notify kenmore [sears] for a parts dealer near you or if can order one also online companies
Aug 12, 2016 | Dryers
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
How to manually reverse ceiling fan direction.
You did not provide a make or model of your fan, but check your owner's manual if you have one. There should be a website or a service support telephone number to obtain more information. Most ceiling fans have a reversing switch on the fan itself. They can be a pull-chain type or a slide switch.
Jul 25, 2015 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I just installed a new hampton bay ultura 68" ceiling fan and the unit is only controlled by a remote control. The reverse function does not work and the fan only runs in one direction which happens to be...
After researching the complaints on this product I found that the reverse mode can be intermittent, the high speed can be slow at best and the returns of this product back to the store are staggering. Get a new but different model.
Jun 21, 2010 | Heating & Cooling
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Minka Aire Ceiling Fan Logo
500 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
