Question about Kenmore HE2 Plus Front Load Washer
How do I fix my washer when I get the F33 code
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa!@$#$%^
Posted on Mar 04, 2011
How to fix washer, error f33
CLICK HERE
Thanks for using FixYa#$%^
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F33 code poped up
CLICK HERE
Thanks for using FixYa#$%$
Jul 14, 2010 | Kenmore HE2 Plus Front Load Washer
Washer codes F01/F33, have cleaned the pump and
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
F33 displayed in whirlpool duetsport frontloading washer
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Error code f33
Jan 25, 2009 | Kenmore HE2 Plus Front Load Washer
Error Code F33 after new bellow put in. How can I fix it?
Just fixed my F33 error code for GHW9400. This code is for the pressure switch HOSE. Mine had a small pin hole. Cost:: the dealer gave me a free new hose. Remove the top and back. In the top right hand corner (at the back of machine) you will see a small hose attached to the pressure switch box. It is small black& 3/8" and about 2 1/2 ft long coming out of the bottom.. Mine was not attached with anything. Pull off at the top and bottom. Look for even the tiniest hole. Hose probably can't cost a couple of dollers.
Replace and just finished my first error free load. It may be causing your leak too.
Jan 10, 2009 | Whirlpool GHW9400 Front Load Washer
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
338 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
