Question about RCA HD52W56 52" Rear Projection HDTV
Has two images and has u on top and bodem - RCA HD52W56 52" Rear Projection HDTV
  • 51 Answers
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
Posted on Sep 01, 2010
Ik Krijg verschillende kleuren lijnen op m'n lcd van canon g5
Eerst moet je het "model" & "generatie"van uw G5 iMac moet je wetenHoe je je iMac te identificeren http://docs.info.apple.com/article.html?artnum=301724-enVerkrijgen van informatie over uw computer http://docs.info.apple.com/article.html?path=Mac/10.4/en/mh355.html
U kunt deze informatie weergegeven op de bodem van elk bericht door te gaan naar 'Mijn instellingen' die zich bevindt in de kolom aan de rechterkant onder uw naam, en het invullen van de gevraagde informatie.
Controleren om te zien of uw model iMac in aanmerking komt voor een van de iMac G5 reparatieprogramma programma voor video en voeding
Als uw computer niet in aanmerking komt, hopelijk heb je AppleCare.
Mar 21, 2011 | Canon PowerShot G5 Digital Camera
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
How to mix two images ? specially at border of picture.
1. Open the first image.
2. Open the image you want to merge or mix with the first image or border.
3. Press Ctrl + A to select the entire image.
4. Press Ctrl + C to copy the selected image.
5. Click in the title bar of the image you opened first.
6. Press Ctrl + V to paste the second image over the first image.
7. If the Layer window is not displayed press theF7 function on your keyboard.
8. Make sure the top layer is highlighted or click on the layer to highlight it.
You should see the border around the image. If you want to hide part of the top image at the bottom lower left of the layer window you will see rectangle with circle which displays add layer mask when you hover the mouse cursor over it. Hold the Alt key and click on the Add Layer Mask Icon. This will hide the top image until you select the brush with a white color and paint the layer mask layer. The Layer Mask is the black rectangle next to the layer image which must have the white rectangle around it when painting with the brush. If you do not see the top image mixing with the bottom image make sure the black rectangle is selected or click on the black rectangle to select it. If the layered image is selected you will be painting it white and alter the image. If you revile part of the image when painting the mask you can hide it by changing the brush color to black and painting the reviled layer to hide it again. Layer masks are very powerful which you will need to look up in the help files for more information to gain full power of the tool.
Jan 20, 2010 | Adobe Photoshop 7.0 for PC
Ds lite case repair
Ok i can tell you how to do this.
First of all you need to make sure you have a new shell and the tools needed for the job, listed below.
  1. NDS screwdriver - $9.99
  2. #00 screwdriver - $9.99
  3. small pair of adjustable pliers (for replacing case).
  4. Soldering Iron (required to replace top display screen or case)
image 1.
OK. Look at image 1 above. Remove all the screws circled.
if you need to access the top of the DS Look at Image 2 below & remove those screws.
Image 2.
*Tech NOTE * Be careful not to lose ur shoulder button shaft and springs (Image 3 circled in RED) they will come out on you.
Also you will see a small cable circled below in Blue (image 3) Only remove this if you absolutely have to, this connects your display touchpad to your motherboard and can be very difficult to reinstall.
Image 3
Their will also be a white cable (not in pic) this can be unplugged by lifting the little round connector with your fingernail; allowing you to pull it through the hinge.
If you unplug the Black cable and pull it loose, you will definitely have a difficult time getting it back underneath its socket. It's easier to desolder it from the board in the top case ( Image 4 in green)
Image 4
I know this is a lot, just bear with me we're almost done.
This next part you have to use EXTREME CAUTION
To unplug your display cables (image 5) you will have to very carefully lift the little black latch on the connector. You will have to use 2 fingernails, one on each side, to lift these off. IF you only lift from one side you will break the Black latch on the connector making the entire board - garbage! Same for reassembly - be wary pushing the latch back down. The top cable circled in Red is for the bottom display. The bottom one is for the top display. There will be a single screw holding the MotherBoard in place. Remove it and lift the MB out carefully.
Image 5
IMAGE 6
Above (image 6) is the Bottom display assembly. The 3 pieces are held together with adhesive. The display is on teh bottom, the Touchpad in the center, and the top is the protective shielding. They can be pried apart carefully using fingernails or a plastic tool (be very careful not to crack anything)
IMAGE 7- TOP DISPAY
Image 7 is of the top display. Where you see the green circles is where the screw covers are located. use something very small to pry them out. Remove the 4 screws.
Hinge Removal - Image 8
Remove the two screws circled in Image 8 to get the hinge apart. If you are replacing your top display this will greatly help when you are trying to fit the cable back through the hinge hole. The Top can now be safely removed
**TECH NOTE**
Fitting your new cable through the hinge hole can be a bit frustrating. make sure you have separated the top & bottom cases to give yourself more working room. Remove the black and white wires, just out of the way. The cable will go into that thin slot a bit. When you reassemble it make sure to roll the end evenly from top to bottom first. This will help get it through the hole. Then put the round metal ring on afterwards, lastly put the wires through.
your speaker wires are soldered to your top display. To replace the case you will need to remove the wires to go through the hinge, and to replace the display you will have to remove them also (image 9)
Image 9
**Tech nOte**
when reassembling the top and bottom shell take note of the on / off button and the switch. Make sure you line the switch up with the button or you may break it***
Image 10
Image 10 - note the black wire that goes through the hinge. It is "jumped" (meaning it is connected to two places on the board, one next to the other)
Image 11
Image 11
The collar that fits inside the plastic case hole.
Image 12
Circled in green in image 12 is the angle adjuster. This is best installed with a small pair of adjustable pliers.
WOW... we're done!! As far as I can see this is a complete breakdown for anything you would need to fix. I hope this is a great help to you.
Please Rate highly if this helped you
^_^
Sep 17, 2009 | Nintendo DS Lite Console
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
Jpg format images are not poper printing in image runner 400
OPEN THE IMAGE IN MSWORD. SEE IT IN PRINT PREVIEW AND THEN PRINT
ALSO TRY
1. USE GOOD QUALITY PAPER & DONT KEEP PAPERS OPEN AS THEY MAY ABSORB MOISTURE
2. CLEAN TOP GLASS WITH COLIN OR OTHER QUALITY PRODUCT
3. CHECK THAT TOP COVER IS GIVING ENOUGH PRESSURE ON YOUR ORIGINALS
Sep 21, 2008 | Canon imageRUNNER 400S Copier
RCA HD52W56 52" Rear Projection HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
