Question about American Standard WCZ036F Air Conditioner
I purchased a new air conditioning system last year. After only 8 months of air conditioning, the coils need cleaning. My previous air condition never needed it's coils cleaned. Does this sound normal for such a new air conditioner?
  • 70 Answers
Cleaning the coils with in the first year no. Rec to have it service once a year though. Cleaning them every other year. Look at them if you take a flash light and can see light thought the other side they should be good. You can also take your garden hose and clean them your self. Just dont get to close that you bend the fins.
Posted on Aug 31, 2010
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Tip
KNOWING ABOUT CONDENSER
What is a condenser?
Is a device or unit used to condense vapor into liquid. A condenser is simply one component of an air conditioner. Whether you have an outdoor air conditioner or a window unit air conditioner your air conditioner contains a condenser.
Condensers are used in outdoor air conditioning systems as well as heat pump systems. Condensers in an air conditioning unit have very few controls. They will have an on and off switch. Occasionally these air conditioners will also have a brown out option. This option shuts down the compressor when the electrical current is low.
A condenser is simply a heat exchanger. It compresses refrigerants into a hot gas to then condense them into a liquid. A condenser is a major component in a air conditioning or heat pump unit. It moves air across the coils to facilitate the transfer of heat.
In a heat pump unit the condenser has a few more features. It will have a reverse valve that allows the unit to switch back and forth between air conditioning and heating. Even when the unit is heating, it uses the condenser for defrosting the coils. If the coils become layered with frost it will effect the units effectiveness this is defrosted when the reverse valve switches to air conditioning mode to move the hot gases through the coils melting the built up ice. It will automatically switch back to heating mode once the ice is cleared to once again heat the home.
To keep your unit in good operating condition it is vital to keep the area around the condenser clear of all debris as well as keeping the filter clear of dust and dirt. A clean machine makes a happy machine. A happy machine will keep you cool during the summer months and warm during the cold months. It is suggested to change the units filters when they become dirty, depending on your area and conditions near your home this may be as often as once a month or as seldom as every 3 to 6 months. You will have to pay close attention to your units needs to decide the right time to change or clean your unit’s filters.
It is very important no matter what type of unit you have to prevent the blockage of the condenser. If the condenser becomes block it can effect the units efficiency or even cause the until to completely fail. For this reason it is one of the most important components of a cooling or heating system. A condenser allows the maximum airflow to the unit.
Keeping you condenser in good running condition will not only prolong the life of your heat or cooling system but also provide you with the most efficient heat and cooling system saving you money on heat and cooling.www.victorwod1234.blogspot.com
on Apr 08, 2010 | Heating & Cooling
Tip
Save cost with some precautions
Precautions to be taken in air conditioners and to save cost.
These are some useful precautions to be taken in air conditioners (A/C).Improper refrigerant charge can damage your compressor, which is the heart of your air conditioning system; this is an expensive air conditioner repair. Systems improperly charged will cause increased electric bills because this will reduce the efficiency of your air conditioning system. The proper refrigerant charge will provide longer equipment life, lower your utility bills and reduce the need for air conditioning service.
A dirty condenser coil (outside unit) will reduce your air conditioning systems ability to remove and reject heat from your home. This will cause your system to run longer and increase your electric bills. The benefit of a clean condenser coil is proper heat rejection, reduced run time and lower energy bills. A dirty air conditioning condenser can lead to system failure and the need for you air conditioner to be repaired, dirt and house dust that escapes through your air conditioning filter can cling to the cold moist coil. This will restrict the air flow through the coil reducing your air conditioning system of performance and capacity. Maintaining the evaporator coil will ensure that proper air flow is delivered to all areas of your home, increase comfort levels, provide a cleaner healthier indoor environment. Inspecting and changing your air filter on a monthly basis will help prevent air conditioner repairs.
As your air conditioning system removes heat from your home, humidity is extracted from the air. The condensation created by warmer air passing over a cold coil must be drained from your system. This is done through a condensate drain line. The drain must be checked and cleared of algae build up or foreign particles clogging the drain, which could cause water damage to the ceiling or floors of your home. By keeping your air conditioner drain line clear you will reduce the need for air conditioning service and overflow problems which can result in water damage. Proper draining will also aid in maintaining indoor humidity levels.
Cause of air flow
Dirty blower wheels can affect the air flow to your home; limit your air conditioning system's capacity and your comfort. It can also spread dust particles which irritate sinus and allergies. A clean blower wheel and fan motor will provide maximum air flow, improved comfort levels and proper cooling. Most of air conditioner repairs are caused by dirt and the lack of maintenance.
Cause of electrical panel
Your thermostat should be properly calibrated. This will ensure accurate temperature control and operating cycle. This will save you on operating cost and assure your comfort level. Moving parts in need of lubrication can cause increased electrical consumption and air conditioner repairs. This is due to additional power required to overcome the resistance in motors and drive shafts that are not lubricated. Proper system lubrication will offer smooth motor and shaft operation, extended part life and less air conditioner repairs. The electrical components on your air conditioning system should be inspected regularly for signs of wear. Faulty electrical components can lead to very expensive air conditioning repairs. A thorough inspection will reduce the need for air conditioner service if the faulty or worn parts are replaced when found.
Carrying this tips help reduce the amount of air conditioner repairs you will encounter over your air conditioning systems lifespan. If you are in need of air conditioner service make sure the company you choose is licensed and insured to do the required repair work (warranty) .
on Feb 27, 2010 | Heating & Cooling
How often should I have maintenance done on my air conditioner?
You should clean the indoor unit filter at least once a month, pressure wash the condenser coil every quarter, and clean the evaporator coil and fans every year.
May 02, 2017 | Cars & Trucks
97 Grand am v6 up & down idle. Driving =steady acceleration. I've changed, O2 sensor, throttle positioning sensor. Scan is still saying Random misfires? Get warm won't start.
P0300 Random misfire - lean condition , vacuum leak , low fuel pressure , fuel filter plugged partially , mass air flow sensor .
If the misfire is random, check for the following conditions:
System Grounds: Ensure all connections are clean and properly tightened.
MAF: A Mass Air Flow (MAF) sensor output that causes the PCM to sense a lower than normal air flow will cause a lean condition.
Air Induction System: Air leaks into the induction system which bypass the MAF sensor will cause a lean condition. Check for disconnected or damaged vacuum hoses, incorrectly installed or faulty crankcase ventilation valve, or for vacuum leaks at the throttle body, EGR valve, and intake manifold mounting surfaces.
Fuel Pressure: Perform a fuel system pressure test. A faulty fuel pump, plugged filter, or faulty fuel system pressure regulator will contribute to a lean condition.
Injector(s): Perform injector coil/balance test to locate faulty injector(s) contributing to a lean or flooding condition. In addition to the above test, check the condition of the injector O rings.
EGR: Check for leaking valve, adapter, or feed pipes which will contribute to a lean condition or excessive EGR flow.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Oct 21, 2015 | Cars & Trucks
Tip
Condenser Coil Cleaning Condenser Coil Cleaner
One of the most important things to maintaining a highly efficient Air Conditioner is keeping the condenser coil clean. To make your condenser coil cleaning as easy as possible you need to know what to use to clean your coil.
There are a number of different things that can be used to clean your condenser coil. It does not matter whether you are cleaning a central air conditioning unit or a window air conditioning unit. What does matter is the type and location of the coil and the amount of dirt that is in the coil.
When looking at the type of coil cleaner to be used, make sure that the chemical being used is compatible with the type of metal that the coil is made out of. Some chemicals and certain metals do not get along well and should be avoided.
Also, if you condenser coil is severely plugged then a foaming type coil cleaner is a must have item. If the condenser coil just needs to be washed down and is not completely plugged then a mild detergent may be just the tool needed to do the job.
For many units that have regular cleanings, a good quality detergent similar to what you use to wash your car, will work just fine. The main object of the cleaning is to remove the dust, dirt, and grime from the coil to promote better air flow through the coil. If the coil is just plugged with grass or dandelion seeds them a simple hosing off with the water hose may do the trick.
If a foaming cleaner is need to clean a neglected or very dirty coil then look up your local heating and air conditioning supply house and purchase a coil cleaner specifically for cleaning condenser coils. Most of these products are for professional use only and care is needed when using and handling these products.
Condenser coil cleaning can be done by the homeowner if proper care is taken and it will keep you air conditioning unit running great whether it is a central air conditioning unit or a window air conditioning unit. Once you know what to do and how to do it you may find that you will be cleaning your condenser coil a number of times a year to insure top performance from your unit.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
on Jan 10, 2010 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Not blowing cold air
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioning2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Jun 25, 2010 | Carrier 38CKC030 Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
American Standard WCZ036F Air Conditioner Logo
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
