Question about Samsung S760 Digital Camera
Wilwhen i switch my camera on the camera status lamps flickers but the camera does m not switch on.It is not ht e batteries because I have tried different types and makes.It always worked with the batteries I am using.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
How do I get the low beams to run automatically whenever driving instead of flickering?
if you did it yourself and did not use factory lights or ballast then it could be a voltage detection problem. If you did use factory parts then the headlight switch may have failed by coincidence. also check connections at HL plugs and or switch. ???????????
Nov 13, 2014 | 2001 Audi TT
Slight flicker with headlights. Replaced battery which was needed. Headlights still flicker. Had changed out original lamps with brighter lamps. Could this be the problem?
Bad plugs on the bulbs.Bad grounded lights wiring.Bad alternator ground.Bad alternator charge.Bad lights switch.Also ,the new lamps may show more sensibility in voltange change or put more pressure on a older bad wiring link.
Oct 26, 2013 | 2006 Ford Mustang
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
New lamp died - won't light
Did you try unplugging the unit from the wall, replugging, then cycling power?
Oct 31, 2008 | NEC HT1100 Multimedia Projector
Constant flickering
This could be early signs of imminent failure of a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 28, 2007 | Canon PowerShot A85 Digital Camera
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Camera won't turn on ...just there is red lamp is workoing
Here is the link to the user manual for your camera if you need it; ftp://213.61.96.30/camera%2fmanuals%2fdc_c500%2fdc_c500_um-english-cd-0822.pdf The red lamp, if it is flashing/blinking indicates that the self-timer function is on - check page 15 for how to turn it off. If the light is steadily on, and it is the battery/power status light, then the indication is that the battery is faulty or not charged - possibly the fault is with the charger, but more likely a new battery will solve the problem. To get a new battery, go to; http://support.BenQ.com and they should tell you where you can get one, if no luck with them, please post back with which part of Egypt you are in, and i can try to find you a dealer locally. Hope this helps :)
Apr 11, 2007 | BenQ DC C500 Digital Camera
Samsung S760 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
