Question about Samsung SyncMaster 205BW LCD Monitor
My monitor power is just blinking, i can not use teh monitor. Nothing appears on the monitor
  • 11,361 Answers
Look for bad caps with leaking/bulging tops like here: http://s807.photobucket.com/albums/yy352/budm/Samsung%20205BW/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 31, 2010
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
May 18, 2009 | Electrolux Washing Machines
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor won't turn off
Monitor will be like that until it is powered off. Only when it is powered off, the light goes off and there will be nothing on display.
Jan 20, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
E173fpb panal. blinking power light
Take the 4 screws out of the stand and remove it. Remove the 2 screw in monitor cable plug bolts.
Put a steel ruler or butter knife between the seam on the side of the monitor and prize open. This is tough but be sure not to insert your prying tool too far and dont start on a corner. Once a few clips have popped it will come apart easier.
Nov 30, 2008 | Dell E173FPb 17" TFT LCD Monitor
Nothing appears in the monitor
Try to check your hardware in your computer maybe it loose.try to insert properly the processor or other parts of your computer
Feb 15, 2007 | EliteGroup P4VMM2 Motherboard
Samsung SyncMaster 205BW LCD Monitor Logo
294 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
