Question about HP PSC 1610v All-in-One Printer
I want to scan
All i want to do is scan some pictures but on my little screen it says insert black or photo print cartridge in right stall, i dont need to print anything i just want to scan some pics onto my computer and it wont do anything when i hit scan or start scan nothing please help
  • Anonymous May 18, 2008
    Same problem. I want to use it to scan, and I can not do any printing, because I can not buy ink. Is there a way to bypass this?
    I want to note, that is this state. It can be used to read a SD memory card.
I got it to scan. I found this by the grace of God. I have the same problem with the print cartridges. But I was attemting to get into my camera. I went to the 'My computer' Icon on Windows XP. Under that part of the file system, I have the "HP PSC 1600 series" icon under the scanners and printers. I double clicked this, and it allowed me to scan an image.
Posted on May 18, 2008
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Do both stalls need to contain a cartridge, in order to print?
Hi
Yes you are right both the stalls should contain cartridge. However, it is not necessary that the cartridges should contain ink. One of the cartridges can be empty.
Please put empty cartridge on the carriage, even if you want to print a BW document.
Daniel Scott
Jun 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
The printer tell me incert black printer cartidge in right stall. or photo cartidge. I've install the cartide but print does not reconized the installation.
HP Officejet 7200, 7300, and 7400 All-in-One Series - 'Incorrect Print Cartridge' or 'Insert Print Cartridge in...Stall' Message Displays on the All-in-One After Installing a Cartridge Issue After installing a cartridge, the error message Incorrect Print Cartridge or Insert [Black or Photo / Tri-color] print cartridge in [right / left] stall appears on the product control panel. Solution Follow these steps to resolve the issue. Step one: Remove, inspect, and reseat the cartridge The cartridge might not have full electrical contact with the product. Removing and reinstalling the cartridge might help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Use genuine HP cartridges to ensure good quality.
  1. Make sure that the product is turned on. NOTE: Press the power button (c00636182.gif ) to turn on the product.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Open the cartridge latch.
    1. Press down lightly on top of the latch.
    2. Pull out the bottom of the latch to unhook it.
  4. Slide the cartridge out and inspect it. Figure 1: Open the cartridge latch c00211535.gif Open the cartridge latch Figure 2: Slide out the cartridge c00211536.gif Slide out the cartridge CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Copper electrical contacts and ink nozzles c00211537.gif 1 - Copper electrical contacts 2 - Ink nozzles Electrical contacts and ink nozzles
    1. Check the copper electrical contacts for debris. If any debris is evident, proceed to "Step two: Clean the cartridge and carriage contacts."
    2. Make sure that the clear nozzle protective tape has been removed. Figure 4: Remove the clear nozzle protective tape c00211538.gif 1 - The clear nozzle protective tape Remove the clear protective tape CAUTION: Do not try to remove the copper electrical strip.
    3. Look at the number on the cartridge label and make sure it is compatible with the product. Compatible cartridges are listed in the product user guide.
  5. If the cartridge is not compatible, obtain the correct cartridge, and then go to "Step five: Replace the cartridge." If the cartridge is compatible, reinstall it in the product:
    1. Hold the cartridge with the nozzles down and the copper electrical contacts facing the product, and then slide the cartridge into the carriage.
      • Cartridges marked with a triangle go into the left carriage slot.
      • Cartridges marked with a square or pentagon go into the right carriage slot.
      Figure 5: Insert the cartridge into the correct slot c00211539.jpg Insert the cartridge into the correct slot
    2. Push down on the cartridge latch until it snaps closed.
    Figure 6: Slide the cartridge c00211540.gif Slide the cartridge into the slot Figure 7: Close the latch c00211541.gif Close the cartridge latch
  6. Close the product cover.
If the issue continues, get back with me there is a few more options we can try. Have a good day
Jun 24, 2009 | HP Officejet 7210 All-In-One InkJet...
Instructions on installing & changing ink cartridges
Step ten: Install the cartridges
  1. Make sure the product is turned on. The On button is lit when the product is on.
  2. Lift the cartridge door. The carriage moves to the right side of the product. Figure 12: Lift the cartridge door c01331661.jpg
  3. Remove the new cartridge from its packaging and gently remove the plastic tape using the pink pull tab. Figure 13: Remove the tape c01331662.jpg CAUTION: Do not touch copper-colored contacts or retape the cartridges.c01331663.jpg
  4. Slide the tri-color cartridge into the left slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 14: Insert the tri-color cartridge c00620861.gif
  5. Slide the black or photo cartridge into the right slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 15: Insert the black or photo cartridge c00620862.gif
  6. Close the cartridge door.
Step eleven: Align the cartridges
  1. Make sure you have loaded plain white letter or A4 paper in the bottom tray. Press OK to print the alignment page.
  2. Remove the alignment page from the output tray. Figure 16: Print the cartridge alignment page c00620112.gif
  3. Place the alignment page face down into the document feeder. Figure 17: Load the printed alignment page c00620113.gif
  4. Press OK to scan the alignment page. After the page has scanned, alignment is complete
Apr 12, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP PSC 1300 All in one Printer
    1. Turn on the HP PSC and lower the print-carriage access door.
      The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
        NOTE: The black cartridge is on the right side of the print carriage.
      Figure 2: Removing the print cartridge
        NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
        CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
      Figure 3: Removing the plastic tape
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
        CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
      Figure 4: Inserting the print cartridge
    5. Close the print-carriage access door.
    Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
    The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
    With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
    Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
    c00034854.jpg 1 - Inserting the print cartridge
    2 - Removing the print cartridge
    Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
    1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
    2. Press Scan .
      The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
    Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
    Print Cartridge in Right Stall not Supported.
    print cartridge colour ink is not workink fix with hp print
    May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    HP PSC 1610v All-in-One Printer Logo
    104 people viewed this question
    Ben Johnson
