Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
The bottom floor of the freezer keeps icing up badly and I can't find how to check for a blocked pipe anywhere and there doesn't seem to be a drain hole in the freezer
    President:
  • 3,773 Answers
Clear the drain under the cooling coils in freezer. This normally causes this problem. Ice could be hiding the drain hole
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Why does ice keep forming in the bottom of the refrigerator
If you are referring to ice forming on the floor of the freezer, it's a result of a blocked defrost drain. Contact Maytag to send out an authorized service company to make repairs. There is a drain kit that is installed at no cost to you.
Sep 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Puddle on floor
dear Damian sounds like the drain from the freezer is clogged you need to unclogg it and make sure the water flows through. Now if its not visible you need to unplug the fridge take out the shelves and unscrew the back panel.Then at the bottom of the evaporator (the winding pipes ) there should be a block of ice which needs to be defrosted until you see the drain hole that must also be free of ice and that will be the hardest part. To unclogg the ice from the hole you will need some hot water to pour into the hole let it melt a bit then sponge it out and repeat process until the water flows directly through. hope this helps good luck. regards Tony
Dec 12, 2011 | LG LSC26905TT Side by Side Refrigerator
Have a TFX26ZPDA that occassionally leaks from front freezer corner. notice of leak anywhere, but find water under the fridge on the floor (facing fridge left bottom)..........why is this
I would check the bottom of the freezer. If its a solid block of ice then you have a frozen drain line. You may have to remove the back panel to access the drain or on some models there is a gap there its located in the back. If you take a turnkey baster and fill it with hot water and keep shooting it down the drain line it should eventually thaw out. The water is coming from your evaporator coils when they defrost.
Hope this helps _MJ_
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Drain iced up in freezer
the draining pipe is block with something, you can melt the ice with a hear drier or hot water, then put a wire true the pipe and after that, test the pipe again.
Jun 02, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
97 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
