Question about Ricoh 3310Le Fax Machine, FAX3310Le Printer
How do you reset the ADF counter after I replace the ADF maintenance kit?
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
SOURCE: Reset counter on Xerox Phaser 8200
The "counter" is an electronic module that is replaced when you replace the maintenance kit, this module measures "usage" but may also hold time & date info (possibly set from the printers internal clock).... I hear it is possible to reset this module but you will need a piece of equipment (chip resetter) that most of us don't have, I think someone on eBay is offering reset chips for $37 shipped.
Posted on Nov 30, 2008
SOURCE: how to reset maintenance counter on a Dell 5310
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
Posted on Jul 22, 2009
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
SOURCE: Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Posted on Nov 24, 2009
How do I reset Z6100 maintenance counter?
POwer off the printer and then depress the Maintenance button now Power On the printer till it resets which is for few seconds
Jun 25, 2015 | HP Designjet Z6100 InkJet Printer
Maintenance reset
Reset the maintenance-kit counter
1. Turn the product power off and then on.
2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.
3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.
4. Press OK to reset the maintenance-kit counter.
May 22, 2013 | HP Laserjet P4515x Printer
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Lexmark 463de maintenance reset
To reset the maintenance page counter to zero:
1. Touch Reset Maintenance Counter from the Configuration Menu.
2. Reset Maintenance Counter appears in the header.
3. Touch 100K Kit or 600K Kit. Yes and No appear in a menu.
4. To cancel the reset operation, touch Back or No. All other button presses are ignored.
5. To initiate the reset operation, touch Yes.
Dec 03, 2012 | Lexmark "x463de multifunction laser...
What should i do, my printer is requesting me to replace document feeder kit and i dont know what to do. help me out please. MIKE
Never mind, I noticed the model in the subject. Sorry, it is Monday morning. Ideally you need to order a new ADF Maintenance Kit and replace the parts in it to maintain optimal performance of your printer. It comes with a pickup roller, separation pad, mylar sheet and instructions. After you replace the kit, or if you just want to reset the message and ignore it for another 90k copies, do this:
1) Turn the machine off and back on. 2) When XXXMB appears on the control panel display, press and hold the 6 button until all three LEDs flash once and then stay on. (This could take about 20 secs to happen) 3) Release the 6 button and then press the 3 button twice. 4) Press the 6 button to select NEW DOCUMENT FEEDER KIT.
After doing this, the MFP will complete its initialization sequence and the counter will be automatically reset.
The part number for the maintenance kit is: Q5997A, Amazon has it for about $91
Hopefully that helps.
Feb 21, 2011 | HP LaserJet 4345mfp Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Fax machine error
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
Jan 29, 2007 | Ricoh FAX5510L Plain Paper Laser
221 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
