Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
WERE IS THE THERMOCOUPLE LOCATED ON THE HEATER AND IS IT EASY TO REPLACE ?
  • 70 Answers
It is eather elec ing or have a millivolt rod which should be on the piolt assy. If not hot service or spark ing. But all will be at piolt assy.
Posted on Aug 31, 2010
2 Suggested Answers
  • 221 Answers
SOURCE: Easy way to replace the thermocouple
I suppose it would be easier to replace the thermocouple than the thermostat. Once you have the thermocouple in your hand, the installation is self explanatory. If you describe the problem, maybe the correct solution will come.
Posted on Jan 10, 2010
Whirlpool gas water heater pilot light will not relight
Are you holding the pilot button in long enough. Sometimes it takes a long time for the thermocouple to open. Or you need a new thermocouple, there cheap and easy to replace.
Feb 04, 2014 | Whirlpool Water Heaters
ChangeThermocouple on Kenmore model 153.339462
Copy following link for replacing thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
Push in TCO located on front of unit and clean air intake/ arrestor screen located under the water heater
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
With this water heater, you will replace pilot assembly, contact AO Smith for part 9003542. Or Buy amazon.
http://c.sears.com/assets/own/pm9g6e.pdf
http://www.amazon.com/dp/B000XOEZ9U/?tag=waterheaterti-20
Add comment and say what you discover
May 13, 2013 | Water Heaters
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Add comment and say what you tried so far.
Include age of water heater.
Jan 05, 2013 | Reliance & LP Gas Water Heater Control
Find filters on a kenmore miser 6 gas water heater
1) Are you looking for air intake screen located on bottom of water heater? Clean with compressed air or feather duster.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
2) Kenmore water heaters are made by AO-Smith/ American
Stand 3-legged water heaters are bricks so air intake is easy to clean.
Dec 29, 2012 | Water Heaters
1) Copy following link to replace thermocouple, and general troubleshoot by type of gas control valve.
2) Reliance gas water heater is same as AO-Smith/ American/ Craftmaster/ State etc.
Air intake is located on bottom of tank.
Use compressed air or feather duster and clean air intake before replacing parts etc.
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
3) Add a comment Dec 2012 with more detail, or for followup help as needed.
Dec 13, 2012 | Water Heaters
I HAVE A PROPANE 75-125000 BTU REDDING HEATER. WHEN I RELEASE THE STARTER BUTTON THE FLAME GOES OUT. I TRIED HOLDING SEVERAL MINS AND IT STILL GOES OUT. HELP!!!
You will need to replace the pilot safety or commonly called Thermocouple. It is the probe located in the flame disc and works its way back to the gas valve. Remove it and take it to a good hardware store. You may have to purchase a longer one but you can keep it coiled to make it fit. Real easy to replace.
Jan 23, 2011 | Reddy Heater-30-55,000 BTU Variable
My oven is on warming mode from last six hours. Please adivse
First, check the back of the oven. See if the lil red button can be pressed in. Then check the IR Element, usually you can see the wires burned or damaged where it enters the oven by the snap rings. This was a design flaw from the manufacturer of the element of which turbochef has taken care of.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Its typically an easy quick fix.
Nov 02, 2010 | TurboChef TORNADO Electric Oven
Pilot will not relight properly on 40 gallon natural gas hot water heater
The thermocouple needs to be replaced. That is what keeps the pilot light lit. The thermocouple is the little metal probe that sticks up into the pilot flame. Very easy to replace.
heatman101
Mar 25, 2010 | Whirlpool Water Heaters
Patio Heater won't stay lit?
The first possibility is a bad regulator, easy and cheap to replace. The second possibility is a bad thermocouple, and the third possibility is a blockage in the pilot assembly. The last two problems require you to take the head apart to replace the thermocouple or clear the blockage. If you are not comfortable taking the head apart, hire someone to do it.
Jun 14, 2009 | Endless Summer gwt501a Open Flame Patio...
Pilot wont stay lit installed new gas valve and new thermocouple
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Jan 28, 2009 | Dayton Gas Furnace Heater
Heating & Cooling Logo
93 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
