Question about Razer Diamondback Mouse
Razer Diamondback turning off and on
Hey i have a very annoying problem that annoys me a lot. My razer diamondback mouse turns off and after ~5seconds turns on again, sometimes i need to replug it to make it work again. I tried to reinstalling windows but it didn't help. P.S. The longer computer is being switched ON, the more often mouse turns off/on.
  • 8 more comments
  • portableman May 09, 2008
    P.S. When mouse turns off it shows a table writing "The USB Device is not recognised" or something like that.
  • ghutor May 19, 2008
    got exact sam problem :/
  • frgmchine May 26, 2008
    İ've got this problem too..
  • Oxid Jun 03, 2008
    Ye ive got the same prob some days ago, driving me mad. Some times when It turns off my comp shutdown. and that affect such things as workings in progress may be lost, torrent seeding fucks up and gaming Is something I couldnt even imagine trying out. You see my point? 1 small prob that fucks upp everythuing.
    My friends razer even burned up after having these problems for a long time ;D
  • Anonymous Jun 08, 2008
    Yeah same thing for me
  • Anonymous Jun 15, 2008
    same here, my buddy had the problem happen to 2 of them, its something to do with the inside of if, because mine seems to only hapen when gaming, while im lifting it off the pad and placing it back down is when it seems to shut off. I think something in the wiring inside gets fucked up over time with lots of use. Ive had mine for over a year now so im just gonna buy a new one.
  • Anonymous Jul 22, 2008
    Yep same proble any solution for that??
  • portableman Sep 28, 2008
    how to fix cable?
  • Anonymous Nov 30, 2008
    I HAVE SAME PROBLEM!!!!!!!!!!!!!
    Its "illegal" to tamper with their device and it voids any possible warranty. I cant get a receipt anyways. :)
    try buying a cheap *** mouse and seeing if it has the same cable. :p
  • Anonymous Dec 29, 2008
    yep. I decided to browse google and I found this topic bout razer DIAs switchin off. I have the same problem - the thing is - yesterday it switched off, then automatically on, but today, when I started my computer it switches off and I can turn it on only by repluging it. Man, now I'm plugging it into the front usb, this looks so pathetic. Anyways I've had this mouse for almost two years and the next mouse I'm gonna buy is definitely gonna be razer. I think I'll try deathadder now. peace.
    ps. anyways, sadface. ={
Can't say if your issue is exactly the same as the one i had but my razer diamondback kept cutting out just like how you said, i fixed it by taking it apart and replacing the cable with one from an old dell optical mouse i had knocking around. inside the mouse is a small plastic plug with 5 wires attatched i had to rearrange the wires going into the plug by removing the spades and swapping them around so they matched the original plug.
i found the best way to remove the spades is to get a fine pin or needle and lift the little bit of plastic holding them in, if you do this right they will slide out effortlessly, make sure when you rearange the wires that they're put in the same way as the cable you are replacing else it may not work properly.
put the mouse back together and plug in and it should be fine, it took me 10 mins to do this to my diamondback and its working like new again.
Posted on Jul 28, 2009
The cable on all of my razer mice seems to pinch, ironically, right at the rubber gasket designed to keep it from pinching, near the front of the mouse. My solution was to find a free USB device (in my case it was a keyboard) off of craigslist, the internal USB attachment was the same. I used a razor to split the small rubber gasket bit off of the old cable, this new one is thick so I don't think it will pinch it. I had to make a few small cuts in the rubber to get the top to snap into place, but it works fine now for the past few months. I can see myself getting another 4 years out of it.
Posted on Mar 24, 2009
    New Friend:
Lol, i wrote it down on a pc of paper: "make sure when you rearange the wires that they're put in the same way as the cable you are replacing else it may not work properly."
now the paper is gone!!!, anyone of you want to take a photo of the cables??
Posted on Sep 28, 2014
  • 67 Answers
This isn't a solution, i have the same problem only its nto a break in the cord.. logically it cant be.. i have a cord holder and on either side of it i can wiggle it to hell and the problem doesnt occur.. its really random from my perspective.. im thinkin its a software problem but i reinstallled the drivers and its still doin it.
Posted on Feb 08, 2010
I Have the same problem as well, it is the cord where it enters the mouse. (for me atleast)
I just took the top of it off and messed around with it a little... definitely the cord. Just asked tech support if they could sell me a new cord, we'll see how that goes
Posted on Nov 25, 2008
It is actually because the cable is busted and has a break in it somewhere. I'm wondering where I can order/get a replacement cable from.
Posted on Sep 17, 2008
Same freaking problem
Posted on Jun 20, 2008
  • Buckshot Brian Sep 26, 2010
    Definitely a software issue -- Razer Diamondback mouse will initially work fine, but then fails to work after computer sits idle for period of time. Only solution is to unplug mouse, then plug it back in again. People who say it's a cord issue are probably Razer plants... Way to go Razer in testing your product before bringing it to market...
I need a manual for a model 1600 mouse
You could try
if you need a user manual
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 07, 2011 | Razer Diamondback Mouse
The click does not always work
yes, the parts quality of mouse, is now apreciated. Maybe is low quality China Model, dont expect much. So my experience, recomends Microsoft Mouses and Keyboards, It´s more expensive, or less design, but works all days, year after year, is good hardware, no question
Nov 29, 2009 | Razer Diamondback Mouse
Hi. I have bought a mouse razer diamondback 3g 2 years ago. Since now i didnt have any problems with it. In the last 3-4 days it just does not click every time i press it and the scroll ocasionaly does not...
its either the contact for buttons and mouse have worn, or the wiring into mouse has became damaged try holding the wire sharply one way to see if it makes differnce, really aint much you can do here other than find is it break in wire or is it contact s to buttons damaged.
Razer Lachesis dont turn on after reboot???
Dec 18, 2008 | Razer RZ01050300 Mouse
Razor DiamondBack
Your best bet is to probably reinstall the Razor Diamondback drivers.
You can access the latest drivers from here:
Be sure to install the correct drivers for your operating system.
Nov 02, 2008 | Razer Diamondback Mouse
Erratic Logitech cordless optical mouse
ive had the mx700 for two years and im very comfortable with it.
I think you problem lies not with the mouse or the driver, but rather the mousepad.
Since the mx700 is not a lasermouse, but "only" optical, it still needs a decent pad to work flawlessly.
Ive had problems with these kind of mice using blank paper, magazines or tablesurfaces.
Try to get a real mousepad from somewhere (should be really cheap), that should do the trick =)
I upgradet to a razer diamondback later which is a laser mouse (1600dpi, while optical mice (with the red light) have 800dpi). Some ppl say that this is too much, and not needed (you can get even higher specs =) but i felt a world of difference, it just works everywhere! (except for mirrors and glas =)
Feb 11, 2008 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Razer Diamondback
under the big plastic slide of the mouse theres a screw you just need to take out .. then gently pop it open the bottom end and pull it back.. DON"T TRY TO PULL IT OPEN COMPLETELY.. there is a little hinge that holds the top 2 buttons in place. just pry open the lower end and gently pull back.
Oct 31, 2007 | Razer Diamondback
Razer Diamondback turning on and off
acually, your problem is windows updates, I am using vista, and I have a Razer Copeprhead, I had similar problems as you, my mouse was working fine, but an update for the Razer Auto-Installed from Windows Update, which made my mouse start doing it. First it happened on my computer, now it happened on my dad's laptop, I first assumed the internal connection was damaged, so I was beating my mouse to death....CoD4 with mouse failure = ANGRY RAMPAGE! lol. So yea what it is is you have to COMPLETELY uninstall your drivers, then connect the mouse and re-install drivers, there ya go done!
Oct 24, 2007 | Microsoft MS RAZER|DIAMONDBK RZD-1600P...
Razer Diamondback Mouse Logo
2,586 people viewed this question
Top Razer Video Game Consoles & Games Experts
James Wishart
Are you a Razer Video Game Console and Game Expert? Answer questions, earn points and help others
