Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
How to remove ford 4000 hydraulic filter - RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
3 Suggested Answers
  • 172 Answers
SOURCE: where will i find the hydraulic filter on my
The filter and suction strainer should be behind the hitch or "lift" cover. There will be a paper filter element normally with a suction screen under it. Be sure to pull the suction screen and clean the area surrounding it. You may be able to call your the Ford/New holland dealer for your area and get a little more precise information also. As I recall these are common sump with the transmission, but I could be mistaken on that. Best regards, Marvin
Posted on Jan 19, 2010
Testimonial: "thanks so much all the manuals i had found didn't help "
  • 469 Answers
SOURCE: ford 4000 hydraulic problems
First, make sure there is plenty of hydraulic oil in the reservoir
2nd, no leaks that are dumping the pressure
3rd, no blockage in tubes, located inside pump housing.
4th, make sure operating handle is engaging
try these and if nothing works let me know.
Posted on Mar 23, 2011
Ford 7810 series 2 hydraulics have gone very slow have pressure tested tractor and it is OK until you rev it up the pressure goes oil sound like it is sergin in back end of tractor oil level OK ?
Best advice is for you to list this in Lawn and Garden or Construction equipment section for Tractors. There is a valve knob on a 4000 series that proportions hydraulic flow from more in back than front depending on the setting. If you have a front loader or if you have rear attachments you can get more action on the end you want. On a 4000 the knob is by the right heel of the driver. Could work like this for 7810.
Jul 20, 2017 | Ford Cars & Trucks
1966 ford 4000 tractor leaking milky white hydraulic fluid out of where the gear shift is. looks like foam
The "milky foam look" is a CLASSIC sign that there is water (or maybe antifreeze) mixed in with something that has a petroleum base ... such a oil or hydraulic fluid!
May 08, 2017 | Ford Cars & Trucks
Where is the hydraulic filter on a 1964 Ford 4000 tractor
It has a filter inside the hydraulic pump canister in pump on engine.
Nov 13, 2016 | Ford Garden
Where can I find parts and instructions on how to repair the hydraulic rear remote level selector on a ford 4000 1965 Gas Row crop tractor?
what ive found on these oldies are that they borrowed the seals from there car/truck line , me id remove the leaking seal and take it with you and find an autoparts guy that's willing to look up an item by size/description then I bet you could buy a seal that would work for you
also for seals/bearings a company called timkin has a fantastic web site that allows one to get a part number by size !!!
Nov 16, 2015 | Ford Garden
Hydraulics wont lift
well it could be wrong fluid for winter use it could be fliter problem or even a pump problem
Mar 15, 2015 | A&I Products A-C4NN10002A,Ford / New...
WHERE DO I ADD HYDROLUIC FLUID IN A FORD 30000 Tractor
On the floor pan next to the gear shiftier you will see a raised
BOLT, unscrew and you will find a screen filter inside, take filter out and clean with diesel fuel, replace filter. You can add the hydraulic
fluid there as well. NOTE: Purchase a owners manual on ebay they are important to have, and will more than pay themselves.
Feb 18, 2015 | RTO Ford Tractor 2000 3000 4000 5000 Water...
What type of fluid in used in 1971 ford 4000
The 1970 ford 4000 had 3 engine options; gas, diesel, and lp. If there is no canister that looks like a propane tank then it is gas or diesel. A gas engine will have spark plugs and wires and the diesel will not. The only fluid that is going to be different is what kind of fuel it runs on. Any dealership that sells tractors should be able to show you how to service yours. Manuals are available on line. And next time specify what fluid you are talking about; transmission, hydraulic, coolant, break, power steering, etc. We can't read minds.
Nov 27, 2014 | Garden
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford 4000 hydraulic problems
Jan 23, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Where will i find the hydraulic filter on my
Jan 19, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
2,978 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
