Question about Makita 15/16" Rotary Hammer, SDS, 3-mode, var. spd., reversible, L.E.D. Light, case
Sum think rong with cluch chuck not turning motor is running
  • 90 Answers
Sounds like a strpped gear or broken shaft. look in the gearbox where the motor shaft goes into the gearbox. if that is ok go to the where the chuck spindle comes out of the gearbox.
Posted on Sep 01, 2010
How to remove chuck
Sometimes there is a screw in the middle inside the chuck remove the inside screw beware to get it out turn it allways clockwise instead of counterclockwise. it that was done but the chuck itself must be turn off counterclockwise. SImply take the most great possible allen wrench set it in and converts the longest section firmly in a vise or other good fixative object (always wear safety glasses )and if its possible turn in the left make power connection and keep the machine firmly and give the case even with the rotational force a short brisk turn, and then he runs quietly from the ashes.
from a Jacobs chuck with a key to a keyless chuck, I think, but if no screw inside is present , heat the chuck slowly with a gas heater and use a preferred green colored loctite for screwless chucks to remove is the same way as described.
Jan 02, 2016 | Drills
Chuck will not turn
Make sure the torque selector which is the black ring with numbers and a drill symbol on it behind the chuck is rotated to the drill image for drilling and general purpose use.
Feb 11, 2012 | Dewalt 18 Volt Compact Drill Kit
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
Lacks power
well your clutch could be slipping but
Feb 26, 2010 | 1997 Chevrolet S-10 Pickup
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Fan will not come on,but it turns.need to know if there's a reset button or cluch reset?
I think that some models have areset button on/near the motor. Look on the end of the motor for a red button.
--W/D--
Aug 18, 2009 | Lakewood MC-42 Fan
New head job radiator thermostat water pump computer and still running hot
WELL SOMTIMES YOU WILL GET WATER PUMPS THAT TURNE THE RONG WAY BUT YOU DID NOT SAY FAN CLUTCH COULD BE BAD THIS WILL COUSE OVER HEATING IF YOU NEED TO NO HOW TO TEST LET ME KNOW BUT IF YOU THINK YOU HAVE FLOW ISUSES YOU CAN GO TO ACE OR SOMTHING LIKE THAT BUY CLEAR HOSE SO YOU CAN WATCH FLOW OR YOU OR THE HEAD GASKETS CAN BE ON RONG OR RONG YEAR. HOPE THIS HELPS
Aug 07, 2009 | 2001 Ford Ranger Regular Cab
K700i keeps restarting
While transferring data from from another phone via blue tooth it would have got corrupted.I suggest you go back to the factory settings in your phone and press Restore Factory Settings.If this does not work you will have to take it to the phone shop and get it formatted which will solve your problem.
Dec 16, 2007 | Sony Ericsson K700i Cellular Phone
Makita 15/16" Rotary Hammer, SDS, 3-mode, var. spd., reversible, L.E.D. Light, case Logo
135 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
