Question about Acer Extensa 4620 Notebook
My right hinge is broken and my monitor keeps falling backward and frontwards
  • 131 Answers
If it is under warranty, contact Acer. If not, search for a hinge kit for it or take it into a repair shop.
Posted on Aug 31, 2010
The screen falls backwards when I open. How do I secure it?
replace the hinges. on the left and right side of the screen is a matelic hinge what's holding yhe screen in place.
Apr 26, 2014 | Toshiba Satellite 1415-S173 Notebook
Door adjust for 71 Chev C20
  • Open the door and locate the two hinges where the door pivots from the vehicle.
  • 2Look for any wear or bending on either hinge. The hinge that looks bent or otherwise damaged will be the one you want to adjust.
  • 3
    Loosen the bolts with the socket wrench on the affected hinge just enough to where it could be moved with the pry bar.
  • 4Move the hinge forward or backward in small increments, then gently try to close the door to see if it is back in alignment. If it isn't, continue to move it either frontward or backward until the door closes securely and without slamming.
  • 5
    Tighten all parts
  • Sep 04, 2012 | Chevrolet Chevrolet Cars & Trucks
    How do I know if the hinge is broken on the stove door?
    the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
    Apr 20, 2012 | Brown Stove Works Ovens
    The right hinge on the monitor is broken and the the monitor does not work at all. It appears the hinge locks on two hoop-like catches, and one of the two is broken. Thank you
    hello your screen will not work because the wirering that comes from the laptop to the monitor has either broken or came away from its plug it would be best to leave it into a repair shop i hope this helps you goodluck
    Mar 30, 2011 | Averatec AV7170-EC1 Notebook
    My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
    I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
    Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
    Also remove the 3 screws holding the left-side foot on.
    Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
    If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
    By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
    Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
    Lid support broke
    Not much info but if you mean the lid on your DS falls backward when opened then one of two things has happened either the small barrel lock in the hinge has broken, this is rare. Or you have broken the hinge allowing the barrel lock to rotate in the case.
    The barrel is cheap and a very easy fix by opening the case removing the led lens holder then change the lock. If you have broken the hinge you will need to replace the case, tricky job requiring patience especially when transfering the top screen to the new case. Watch a few you tube instruction videos to get a better idea of whats involved.
    Jun 10, 2009 | Nintendo DS Lite Console
    Screen on Sony VAIO PCG-SRX99 needs to be tightened.
    you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
    good luck
    ruben
    Apr 06, 2009 | Sony VAIO SRX99 Notebook
    Car goes into gear, but won't move
    You need to check the transmission if any gears is broken inside the transmission it will cause this problem .
    Feb 21, 2009 | 1995 Ford Escort
    Top Hinge Broken (drat...)
    you should keep it.....try model glue.........use very little tho
    Aug 10, 2008 | Nintendo DS Console
    Monitor dark; hinges broken
    He may have damaged the inverter or left the cables disconnected from the backlights. The inverter supplies the required voltage to the LCD Back lights.
    Mar 31, 2008 | Toshiba Satellite A25-S207 Notebook
    Acer Extensa 4620 Notebook Logo
    97 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
