Question about Dell Optiplex GX50 Intel Desktop PC - Intel Celeron 900MHz, 128MB RAM, 10GB HDD, CD-ROM,
My dell optiplex gx50 power button shows solid amber light
MyTechGuru
  • 93 Answers
SOURCE: solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Posted on Aug 14, 2008
jelacio
  • 10 Answers
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Posted on Aug 20, 2008
  • 998 Answers
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
  • 31 Answers
SOURCE: amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Posted on Nov 30, 2008
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
How do I fix problems of Dell computer 780 with power light yellow and black screen?
getnet,
What do the diagnostic led lights show. The diagnostic LEDs are located on the front of the chassis next to the power button. These diagnostic LEDs are only active and visible during the POST process. Once the operating system starts to load, they turn off and are no longer visible. Below is the manual that provides information on what the led pattern shows to help resolve the issue.
Optiplex 780 manual
http://dell.to/1HqoNmD
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 20, 2014 | Dell Computers & Internet
B and C diagnostic light on back of dell optiplex gx50 are amber and i can't get past the dell logo with loading bar (loads 3/4 of the bar) nor can i get into bios please help p.s. there is no os. i...
Try contacting dell, they should be able to help you.
Here is a link that will explain what the diagnostic lights mean. This is for all Dell Desktop PC's.
http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
I hope this helps.
Good luck and have a pleasent day.
Jun 22, 2011 | Dell Optiplex GX50 Intel Desktop PC -...
Hello! I have a dell optiplex gx260 pc i am having a problem that my pc does not boot it does not show any screen nor any beep its backlight light orders are A OFF B Yellow C OFF D OFF i have...
If the power LED is flashing amber, there may be an issue with the power supply, if it is solid amber then the motherboard itself (or if it has an expansion card in a slot, maybe the card)
Jun 08, 2011 | Dell OptiPlex GX260 PC Desktop
What is the flashing amber light and how can i fix it on my own
Flashing Amber light might indicate that the power supply is not working correctly. Replace the power supply.
I found a website that sells them and they have pictures to see how the power supply looks like. Open your computer and see which one you have and look around for the best deal.
http://www.discountelectronics.com/index.php?l=product_list&c=5460&gclid=CJybyavBwqUCFdJf2godTVGCag
Nov 27, 2010 | Dell Optiplex GX50 Intel Desktop PC -...
I have a Dell Optiplex 210L when i push the power button a solid amber light appear.. thanks any suggestion
Click here to visit dell support. The documentation provides details about the light codes and diagnostic procedure.
I think it is a power issue, which is usually indicated by amber light on dell systems. I came accross dell systems with similar indication and the issue was improper voltage either due to faulty power supply or bad connection.
Therefore, i suggest that: -
First, make sure that the connections and voltage to your system is proper.
Also, get the power sully unit checked by a professional for its proper functioning. I may require repair or replacement.
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | Dell OptiPlex 210L N (210LNDCELMIN) PC...
Amber light flicks once or twice no sound from fan or anything? What do we need to do
If the power button is a solid amber it is likely a motherboard due to a failed capacitor (Check the capacitors on the motherboard see if any tops are bulging)
If flashing amber, most likely a failed power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Aug 30, 2010 | Dell OptiPlex GX280 PC Desktop
MY DELL IS OPTIPLEX 760SFF, IT NOT BOOTING, SHOWING AMBER LIGHT ON THE POWER BUTTON WHEN PLUG TO POWER.
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Proton
Aug 10, 2010 | Computers & Internet
I get orange light on my power button when i power my dell optiplex 330 pc
Flashing Amber, bad power supply
Solid Amber either a bad component connected to motherboard of the motherboard itself has failed
Jun 23, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX50 Intel Desktop PC  - Intel Celeron 900MHz, 128MB RAM, 10GB HDD, CD-ROM,  Logo
272 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
