Question about Dometic Rooftop RV Air Conditioner
The airconditioner runs the compresser seems to be running and the fan is running on hi.however it isn't cooling what could be wrong?
  • Dometic Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
Temperature gage high cooling fans works sometimes coolant level normal
There are 2 cooling fans one that runs Ono and off Witt he temp of the engine and 1 that runs when you turn on the ac. The fans wiring harness can hook up opposite ways. Meaning that the fans can run backwards if it is hooked up wrong. When the fans are running they need to be pulling air inward towards the engine not blowing out through the front of the car. This is the first thing I would check if it isn't running hot but the temp is above normal!!!
Sep 02, 2012 | 1994 Honda Accord
I have a LWHD1500ER. It runs fine, the fan works pretty well, it runs through it's cycles( on then turns cooler off then back after awhile.) but it isn't cooling, the air coming out is not very...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2011 | Heating & Cooling
My 1994 Honda Accord is losing water from the radiator although no water has been under the car. I Also noticed the cooling fan which use to turn on after the car had been turned off, isn't coming on...
There is a fan sensor in the radiator. If the coolant level uncovers the sensor, the fans won't work properly. Your water loss is caused by the engine burning coolant. Look at the exhaust pipe to see if any water is dripping from the tail pipe with the engine running. Diagnosing the problem can be tricky. It can be a blown head gasket or a crack in a cylinder head or block.
Jul 28, 2017 | 1994 Honda Accord
AC (57915.622) fan hi & low working, compressor
heatman101
Jul 14, 2011 | Heating & Cooling
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
heatman101
Jun 11, 2011 | Amana Heating & Cooling
No Cooling. Everything seems to be running. Tubing at cooling coil seems to have an oily substance on it.
You have a leak and the refrigerant leaves the oil behind when it comes out...
heatman101
May 31, 2011 | Heating & Cooling
My air conditioner fan is running but there isn't any cool air blowing from the vents
heatman101
Apr 20, 2011 | Coleman Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Dometic Rooftop RV Air Conditioner Logo
73 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
