Question about Kenmore Washing Machines
WASHER WILL NOT DRAIN - Kenmore Washing Machines
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 31, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
CHANGE DRAIN PUMP WASHER
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have A WhirlPool Cabrio.. when i start a load.. it flashes "FL' and beeps excessively.. how can i fix and prevent that?
Feb 20, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Kept flashing f21. I hit stop. Now the door won't unlock.
You did not mention whether the washer actually pumps the water out of the washer when you are getting the F21 code. If the washer pumps the water out okay, then the pump and drain system are okay.
Excessive suds can prevent the pump from evacuating the water properly and will sometimes result in an F21. When the suds dissipate, the washer will then be able to pump out the water. Look for this type of condition if necessary.
If the drain pump runs but the washer will not drain the water, see if the washer will gravity drain. Pull the drain hose out of the stand pipe or sink and place it in a shallow pan at floor level. If the washer will gravity drain okay but will not drain when the drain pump is running then you will likely need to replace the drain pump.
If the washer will not gravity drain, then you still have a clog somewhere in the drain system. If you have not pulled the hose between the tub and the pump, then you could have a clog in this area.
If the washer does drain normally, then you could have a failed pressure switch, air pressure hose problem, wiring failure or a failed control board.
Jan 06, 2011 | Kenmore HE2 Plus Front Load Washer
Hello, my washer is flashing a code F 21 what does this mean?
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
Check your washer drain to make sure that it is draining properly.
Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Place a shallow pan on the floor beside the washer and then pull the drain hose out and place the end of it in the shallow pan to see if the washer will gravity drain. If it does, then excessive suds or a drain pump problem could be causing this failure. If the water does not drain or drains extremely slowly, you could have a clog in the drain system of the washer.
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
Keep getting error code sd or 5d and sometimes a F error on my HE 2plus washer. Is there an inexpensive solution to the problem or should we be shopping for a new washer?
Hi
The Sd or 5d indicates that excessive suds are detected by the washer during the drain or spin phases of the cycle. The washer will stop and fill with 4 liters of water and then wait for 5 minutes to allow the suds to dissipate before continuing. If the suds cannot be reduced or eliminated so that the washer cycle can continue, it may stop and display the F21 (long drain) fault code. After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
And if you still face the same error then probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Also refer to these diagrams for more details--
Kenmore Drain filter and pump link1
Kenmore Drain filter and pump link2
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag top load washer pavt244aww leaking into drain
Chad -- Your problem most likely is the drain hose is either
a) Clamped tight to a drain line of some sort allowing water to siphon out
b) Washer drain hose is Shoved too far down the drain pipe
c) Drain pipe is lower than tub of washer alllowing water to drain
Oct 18, 2007 | Washing Machines
Washing Machines Logo
12 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
