My carrier air conditioning unit will not cut on, nor will the fan outside on the top of the unit, but the fan inside will.
    President:
  • 3,773 Answers
Check the breaker for 220v or tripped.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
The top of the air conditioning unit is dented so the fan won't turn.
you must remove the ac from the window and take the cabnet off then bend it back with a rubber malet.If you allow it to run you will burn fan motor .if you need more info let me know hope i helped:)
May 21, 2009 | Heating & Cooling
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
