Question about Paragon 632-20 Defrost Timer
632-20 TIMER MANUAL - Paragon 632-20 Defrost Timer
    Problem Solver:
  • 16 Answers
The only manual will be the piece of paper on the inside cover. If you are missing that or need additional instructions you can contact the manufacturer direct using the link below...
http://www.uni-line.com/common/techsupport.aspx
Posted on Nov 15, 2010
Want to set timer on Provalue ts-EA1
Evidently there are several brand names selling TS-EA1 timer
1) Copy following links for possible TS-EA1 timer manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/pdf/TS-EA1-digital-timer-manual.pdf
2) This is a new series of 50 Hz timers made for worldwide 230Volt market.
Manual was written based on other similar timers, and how those timer buttons worked, although there is not another timer with 1:1 same buttons.
3) Add comment and say what you discover when trying to program your timer. Then possible manual can change accordingly.
Jan 06, 2013 | Sunbeam 6 Robinson Home Digital Timer
TIMER MANUAL
Timer is not identified.
Copy following link to help identify timer and download possible manual:
Sometimes questions on fixya are shortened and we cannot see product, or full question.
Add a comment and clearly describe timer and what timer is used for, if this is in-wall timer, plug in timer, indoor, outdoor, programmable or analog, and any information concerning brand and approx age of timer.
Nov 28, 2012 | Hardware & Accessories
GE digital timer DT300 need a free manual
Question posted under GE 15004 timer.
Open following link to identify Intermatic DT300 timer and download possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Open following link to identify GE15091 timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
If the free information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Need a manual for digital timer DT300GE
If the information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | Hardware & Accessories
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Dec 05, 2010 | Hardware & Accessories
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
My automatic timer is not working.
You posted under Intermatic raintight timer.
Add a comment with your model and brand and I have extensive files on timers.
The best diagnostic is the manual override.
1) Click manual override and see if Load (lights, fan, motor) come on.
If manual override clicks on-and-off crisp and clean, but the lights do not come on, check your electric power.
If the manual override does not click crisp and clean, then the timer may be rusty, or timer may need to be replaced. Buy replacement timer and swap out timer mechanisms without changing the box.
If the manual override works fine, and Load turns on-and-off with manual override, then the clock or trippers are next suspect.
2) Check if the dial is turning as time passes.
If the dial is not turning, then the clock motor is bad and you can buy a new clock motor.
If dial is turning, and manual override turns Load on-and-off, then the tripper pins might be worn out, and you can buy new trippers.
3) To buy replacement parts: Timer door has model number of timer. Timer clock located on back of timer mechanism has identifying numbers. You can snap out the timer mechanism using metal spring locate top inside box.
Grainger sells trippers and motors:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Aplus sells motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Intermatic sells motors:
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Paragon 632-20 Defrost Timer Logo
213 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
