Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
My G 3 used to move all over, now does not move at all, or at best very slow.
  • 640 Answers
If your pool cleaner is moving slowly or not at all, there are a few things that you will want to check. Use Pool Pulse to ensure that you have proper flow. If you flow is too low, check your baskets and filter for clogs or obstructions. Check your diaphragm for damage. Replace it if necessary. Check your hose sections for leaks by lifting each section, one at a time, above water. Confirm that your main drain is completely closed.
Posted on May 09, 2011
What can i use to clean my colon out?
a product that uses senna as the ingredient is the best
however with your problem and if you are over 45 years of age , i suggest that you see your doctor and ask for a colonoscopy to check for bowel cancer
Sep 10, 2016 | Cars & Trucks
Tip
Slow wipers
Try lubricating the linkages as these become quite stiff and slow or stop motor.
Under the bonnet there should be a cover over the scuttle between the engine compartment and the windscreen.
Remove the plastic cover, usually fixed by a rubber seal that seals the engine compartment against the bonnet.
Lubricate and clean the joints on the linkages with silicon spay. As the linkages move freely finish up with a grease spray to provide continuing lubrication. Copper grease spray is probably best.
Reassemble cover.
Probably best to repeat after a few weeks and/or if the wipers slow to ensure that there is continuing lubrication
on Mar 12, 2015 | Audi Cars & Trucks
I have protools7 that wont load after I installed porsche design lacie 500gb hardrive
USB 2.0 is extremely slow for the purpose of doing direct recording. External drives are best used for backup after a project is done.
Dec 27, 2014 | LaCie 500GB PORSCHE DESIGN P9220 USB30...
My 88hp Johnson won't tilt up when moving in water unless I am going slow therefore I can't get topend speed what would cause this?
outboard motors some times are designed to not run at speed while tilted as the water pump inlet is above the water line and the engine will over heat and the pump impellor will be destroyed.. With an engine tilted the load from the propeller tends to lift the nose of the boat high and makes it unstable on the water . The best situation is to have the propeller tend to drive the nose down thereby promoting a planeing action that improves economy and speed Once the boat is on the plane you can cut back on the throttle and still maintain the same speed . Moving with the leg tilted should only be used to navigate shallow water at very slow speeds
Jan 26, 2014 | Cars & Trucks
It moving slow
Follow these guidelines to speed up pc:
  • Defragment the Disk drives
  • Defragment the Windows Registry
  • Update Drivers
  • Set Windows for Best Performance
  • Uninstall the Programs you No Longer Use
For more help click here:
http://www.reginout.com/Speed-Up-PC--Learn-The-Tricks-To-Speed-Up-Your-PC-to-Max.html
Jan 17, 2013 | HP Pavilion a1620n (RC655AA) PC Desktop
I have a 98 isuzu rodeo 3.2 ls 4x4 . I bought it used, and since day 1 it has had a noise coming from the rear diff. It only occurs when moving slow forward or reverse. It sound like to me kinda like a...
try draining (check for metal) diff oil and adding new oil with additive. drive around making turns (figure 8 works best) if problem persists after 2 or 3 days check your brakes
Jul 10, 2011 | Isuzu Rodeo Cars & Trucks
I just got a new wireless adaptor and it was ok at first but now its really slow and i have checked my connection and its really good. then i tryed to put my modum into it and its still slow i tryed...
Check if you can update your firmware.
Also what channel are you using? 1,6& 11 are the best channels to use as they dont overlap with any other wireless devices
If you find it is still slow change your channel as it may be crowded and moving to a more free channel with less traffic might save you hours of waiting on Xbox live.
Also try install THIS application this will let you see what networks are around and on what channel so you can best choose what channel is right for you,
LINK
Jan 14, 2011 | Microsoft Xbox 360 Console
Is very slow running lately. Have done all the usual clean ups. What next? Also how do I move more drive space from d to c.
Its best to backup what you need and format the laptop it will run a lot faster as you may have programs taking up space which you no longer use.
Jun 23, 2010 | Acer TravelMate 4010 Notebook
The window motor runs slow then stops it may move a little but does not move the window all the way down or an inch at a time
the cables are fraded, i had the same problem !!
best thing too do is go too ebay and get the whole assembly (and its new) for about 60.00 rather than get it form a parts store for 150.00
Apr 19, 2009 | Chevrolet Silverado 1500 Cars & Trucks
My pc is moveing slow can it move faster
You can make a computer move faster by removing some unecessary program that is installed on your computer to free up some memroy space and the best way to make much faster is upgrading the RAM or memory of the computer because the higher the RAM/memory the faster the computer works..
Hope that helps.......
Sep 06, 2008 | Computers & Internet
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
229 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
